• DevOps
  • 通过AWS EKS 安装的v4.1.3, host主集群显示Devops未安装的问题
AWS EKS
使用 docker/containerd,版本多少
v4.1.3。通过已建好的EKS集群 使用Kubernetes 快速安装。
启用Devops扩展组件之后,host集群无法创建。
    apiVersion: kubesphere.io/v1alpha1
    kind: InstallPlan
      annotations:
        kubesphere.io/creator: admin
      creationTimestamp: “2025-04-11T01:23:18Z”
      finalizers:
      - kubesphere.io/installplan-protection
      generation: 13
      resourceVersion: “366386”
      uid: 3396ea97-352a-43fe-9464-1cf65a1103c4
      clusterScheduling:
        placement:
          clusters:
          - host
      config: |+
        extension:
          apiserver:
            replicas: 1
              limits:
                cpu: 500m
                memory: 1024Mi
              requests:
                memory: 128Mi
                cpu: 100m
        agent:
          apiserver:
            replicas: 1
              limits:
                cpu: 500m
                memory: 1024Mi
              requests:
                memory: 128Mi
                cpu: 100m
          controller:
            replicas: 1
              limits:
                cpu: 500m
                memory: 1024Mi
              requests:
                cpu: 100m
                memory: 128Mi
          jenkins:
            securityRealm:
              openIdConnect:
                # The kubesphere-core api used for jenkins OIDC
                # If you want to access to jenkinsWebUI, the kubesphereCoreApi must be specified and browser-accessible
                # Modifying this configuration will take effect only during installation
                # If you wish for changes to take effect after installation, you need to update the jenkins-casc-config ConfigMap, copy the securityRealm configuration from jenkins.yaml to jenkins_user.yaml, save, and wait for approximately 70 seconds for the changes to take effect.
                kubesphereCoreApi: “http://ks-apiserver:30880
                # The jenkins web URL used for OIDC redirect
                jenkinsURL: “http://devops-jenkins:30180
            Master:
                requests:
                  cpu: 0.5
                  memory: 6Gi
                limits:
                  cpu: 2
                  memory: 6Gi # recommend set same as requests.memory
              # smtp server settings for notification
              smtp:
                EMAIL_SMTP_HOST: “mail.example.com”
                EMAIL_SMTP_PORT: “465”
                EMAIL_USE_SSL: false
                EMAIL_FROM_NAME: “KubeSphere”
                EMAIL_FROM_ADDR: “admin@example.com
                EMAIL_FROM_PASS: “P@ssw0rd”
              # sonarQube settings
              sonarqube:
                serverUrl: ""
                authToken: ""
            persistence:
              storageClass: ""
              accessMode: ReadWriteOnce
            kubeconfigEnabled: true
      enabled: true
      extension:
        version: 1.1.1
      upgradeStrategy: Manual
    status:
      clusterSchedulingStatuses:
        host:
          conditions:
          - lastTransitionTime: “2025-04-11T01:23:55Z”
            message: ’Release “devops-agent” failed: client rate limiter Wait returned
              an error: context deadline exceeded’
            reason: InstallFailed
            status: “False”
            type: Installed
          - lastTransitionTime: “2025-04-11T01:23:52Z”
            message: The extension agent has been successfully initialized.
            reason: Initialized
            status: “True”
            type: Initialized
          configHash: 27c44748d145f42a
          jobName: helm-install-devops-agent-jwcwgq
          releaseName: devops-agent
          state: InstallFailed
          stateHistory:
            state: Preparing
            state: Installing
          targetNamespace: kubesphere-devops-system
          version: 1.1.1
      conditions:
      - lastTransitionTime: “2025-04-11T01:23:20Z”
        message: Install complete
        reason: InstallSuccessful
        status: “True”
        type: Installed
      - lastTransitionTime: “2025-04-11T01:23:18Z”
        message: The extension devops has been successfully initialized.
        reason: Initialized
        status: “True”
        type: Initialized
      enabled: true
      jobName: helm-install-devops-jmw9g5
      releaseName: devops
      state: Installed
      stateHistory:
        state: Preparing
      - lastTransitionTime: “2025-04-11T01:23:19Z”
        state: Installing
        state: Installed
      version: 1.1.1
