尝试用azure的loadbalancer失败后,重装kubesphere,发现报错
TASK [ks-core/ks-core : KubeSphere | Delete Ingress-controller configmap] ******
fatal: [localhost]: FAILED! => {“changed”: true, “cmd”: “/usr/local/bin/kubectl delete cm -n kubesphere-system ks-router-config\n”, “delta”: “0:00:00.092409”, “end”: “2020-11-10 11:37:15.170991”, “msg”: “non-zero return code”, “rc”: 1, “start”: “2020-11-10 11:37:15.078582”, “stderr”: "Error from server (NotFound): configmaps \“ks-router-config\” not found", “stderr_lines”: ["Error from server (NotFound): configmaps \“ks-router-config\” not found"], “stdout”: "", “stdout_lines”: []}
…ignoring
pod描述:
