ks-console无法登录
willqyK零S
- 已编辑
经测试每次要3至5次尝试才可以登录进去,不能登录时登录界面无任何提示和反应,下图是登录失败后的界面
willqyK零S
清理浏览器缓存,第一次登录提示密码错误,继续尝试几次无反应,然后登陆成功,一直循环这种现象
willqyK零S
- 已编辑
没用用到代理,ks-console用的就是nodeport方式暴露,所有pod运行正常
[root@jenkins kubersphere]# kubectl get pods -A |grep kubesphere
kubesphere-controls-system default-http-backend-857d7b6856-s9dtb 1/1 Running 0 9d
kubesphere-controls-system kubectl-admin-58f985d8f6-5lgj9 1/1 Running 1 33d
kubesphere-controls-system kubesphere-router-demo-namespace-559594cddb-4qrdq 1/1 Running 1 9d
kubesphere-devops-system ks-jenkins-54455f5db8-glhbs 1/1 Running 1 33d
kubesphere-devops-system s2ioperator-0 1/1 Running 2 33d
kubesphere-devops-system uc-jenkins-update-center-cd9464fff-r5txz 1/1 Running 0 9d
kubesphere-monitoring-system alertmanager-main-0 2/2 Running 0 9d
kubesphere-monitoring-system alertmanager-main-1 2/2 Running 4 35d
kubesphere-monitoring-system alertmanager-main-2 2/2 Running 4 33d
kubesphere-monitoring-system kube-state-metrics-95c974544-8fjd8 3/3 Running 3 33d
kubesphere-monitoring-system node-exporter-mdqvj 2/2 Running 4 35d
kubesphere-monitoring-system node-exporter-p8glr 2/2 Running 4 35d
kubesphere-monitoring-system node-exporter-s8ffl 2/2 Running 4 35d
kubesphere-monitoring-system node-exporter-vsjkp 2/2 Running 6 33d
kubesphere-monitoring-system notification-manager-deployment-7c8df68d94-bdm25 1/1 Running 1 33d
kubesphere-monitoring-system notification-manager-deployment-7c8df68d94-k6c2l 1/1 Running 2 35d
kubesphere-monitoring-system notification-manager-operator-6958786cd6-lqtkq 2/2 Running 8 35d
kubesphere-monitoring-system prometheus-k8s-0 3/3 Running 36 33d
kubesphere-monitoring-system prometheus-k8s-1 3/3 Running 0 9d
kubesphere-monitoring-system prometheus-operator-84d58bf775-g7hv8 2/2 Running 0 9d
kubesphere-system etcd-65796969c7-g4ds6 1/1 Running 14 35d
kubesphere-system ks-apiserver-6b49b49dd5-4p66x 1/1 Running 7 9d
kubesphere-system ks-apiserver-6b49b49dd5-kph6g 1/1 Running 7 9d
kubesphere-system ks-apiserver-6b49b49dd5-zrp8b 1/1 Running 7 9d
kubesphere-system ks-console-786b9846d4-dc9cs 1/1 Running 0 55m
kubesphere-system ks-console-786b9846d4-lnjtr 1/1 Running 0 55m
kubesphere-system ks-console-786b9846d4-s9r28 1/1 Running 0 55m
kubesphere-system ks-controller-manager-6c98f848-57r72 1/1 Running 0 57m
kubesphere-system ks-controller-manager-6c98f848-jblbp 1/1 Running 0 57m
kubesphere-system ks-controller-manager-6c98f848-x8dvs 1/1 Running 0 57m
kubesphere-system ks-installer-5f9ff5bb56-2nv98 1/1 Running 1 33d
kubesphere-system minio-7bfdb5968b-f6c67 1/1 Running 1 33d
kubesphere-system mysql-7f64d9f584-zwzmz 1/1 Running 1 33d
kubesphere-system openldap-0 1/1 Running 1 33d
kubesphere-system openldap-1 1/1 Running 1 33d
kubesphere-system redis-ha-haproxy-5c6559d588-2f6x8 1/1 Running 3 33d
kubesphere-system redis-ha-haproxy-5c6559d588-4x69j 1/1 Running 287 34d
kubesphere-system redis-ha-haproxy-5c6559d588-rrxv7 1/1 Running 0 9d
kubesphere-system redis-ha-server-0 2/2 Running 0 67m
kubesphere-system redis-ha-server-1 2/2 Running 0 67m
kubesphere-system redis-ha-server-2 2/2 Running 0 66m
ks-apiserver日志
[root@jenkins kubersphere]# kubectl -n kubesphere-system logs --tail 1000 ks-apiserver-6b49b49dd5-4p66x
W1116 09:48:36.460603 1 client_config.go:543] Neither --kubeconfig nor --master was specified. Using the inClusterConfig. This might not work.
I1116 09:48:37.082483 1 apiserver.go:300] Start cache objects
I1116 09:48:38.133390 1 apiserver.go:502] Finished caching objects
I1116 09:48:38.133418 1 apiserver.go:232] Start listening on :9090
E1117 10:31:46.276599 1 token.go:65] EOF
E1117 10:31:46.283219 1 jwt_token.go:45] EOF
E1117 10:31:46.311069 1 authentication.go:60] Unable to authenticate the request due to error: EOF
I1125 10:39:39.376402 1 apiserver.go:539] 100.87.223.26 - "GET /kapis/devops.kubesphere.io/v1alpha2/devops/demo-devops4t6ff/pipelines/demo-pipeline/sonarstatus HTTP/1.1" 404 19 10ms
I1125 11:57:40.355449 1 apiserver.go:539] 100.111.156.128 - "GET /kapis/devops.kubesphere.io/v1alpha2/devops/demo-devops4t6ff/pipelines/demo-pipeline/sonarstatus HTTP/1.1" 404 19 0ms
E1125 17:03:46.992627 1 token.go:142] EOF
E1125 17:03:46.992655 1 token.go:103] EOF
E1125 17:03:46.992665 1 handler.go:299] EOF
I1125 17:03:46.992679 1 apiserver.go:539] 100.87.223.23 - "POST /oauth/token HTTP/1.1" 500 28 88ms
E1125 17:07:12.416702 1 handler.go:275] incorrect password
I1125 17:07:12.546243 1 apiserver.go:539] 100.105.225.38 - "POST /oauth/token HTTP/1.1" 401 32 198ms
E1125 17:42:15.555425 1 handler.go:275] incorrect password
I1125 17:42:15.587489 1 apiserver.go:539] 100.105.225.51 - "POST /oauth/token HTTP/1.1" 401 32 103ms
[root@jenkins kubersphere]# kubectl -n kubesphere-system logs --tail 1000 ks-apiserver-6b49b49dd5-kph6g
W1116 09:47:22.676506 1 client_config.go:543] Neither --kubeconfig nor --master was specified. Using the inClusterConfig. This might not work.
I1116 09:47:24.961818 1 apiserver.go:300] Start cache objects
I1116 09:47:27.201329 1 apiserver.go:502] Finished caching objects
I1116 09:47:27.201343 1 apiserver.go:232] Start listening on :9090
E1117 09:34:18.153713 1 handler.go:275] incorrect password
I1117 09:34:18.275595 1 apiserver.go:539] 100.86.135.210 - "POST /oauth/token HTTP/1.1" 401 32 195ms
E1117 10:31:47.034315 1 token.go:65] EOF
E1117 10:31:47.034333 1 jwt_token.go:45] EOF
E1117 10:31:47.034342 1 authentication.go:60] Unable to authenticate the request due to error: EOF
E1125 10:37:29.935984 1 handler.go:275] incorrect password
I1125 10:37:30.030289 1 apiserver.go:539] 100.111.156.128 - "POST /oauth/token HTTP/1.1" 401 32 94ms
E1125 14:07:19.876748 1 jwt.go:51] token is expired by 15m43s
E1125 14:07:19.876762 1 token.go:57] token is expired by 15m43s
E1125 14:07:19.876765 1 jwt_token.go:45] token is expired by 15m43s
E1125 14:07:19.876769 1 authentication.go:60] Unable to authenticate the request due to error: token is expired by 15m43s
E1125 17:03:45.124594 1 token.go:142] EOF
E1125 17:03:45.124614 1 token.go:103] EOF
E1125 17:03:45.124630 1 handler.go:299] EOF
I1125 17:03:45.124639 1 apiserver.go:539] 100.87.223.23 - "POST /oauth/token HTTP/1.1" 500 28 70ms
[root@jenkins kubersphere]# kubectl -n kubesphere-system logs --tail 1000 ks-apiserver-6b49b49dd5-zrp8b
W1116 09:40:41.882950 1 client_config.go:543] Neither --kubeconfig nor --master was specified. Using the inClusterConfig. This might not work.
I1116 09:40:44.370243 1 apiserver.go:300] Start cache objects
I1116 09:40:45.982826 1 apiserver.go:502] Finished caching objects
I1116 09:40:45.982861 1 apiserver.go:232] Start listening on :9090
E1117 09:28:08.691316 1 jwt.go:51] token is not valid yet
E1117 09:28:08.725781 1 token.go:57] token is not valid yet
E1117 09:28:08.725824 1 jwt_token.go:45] token is not valid yet
E1117 09:28:08.726391 1 authentication.go:60] Unable to authenticate the request due to error: token is not valid yet
E1117 09:28:26.694903 1 jwt.go:51] token is not valid yet
E1117 09:28:26.695101 1 token.go:57] token is not valid yet
E1117 09:28:26.695185 1 jwt_token.go:45] token is not valid yet
E1117 09:28:26.695266 1 authentication.go:60] Unable to authenticate the request due to error: token is not valid yet
E1117 09:28:54.160965 1 jwt.go:51] token is not valid yet
E1117 09:28:54.160985 1 token.go:57] token is not valid yet
E1117 09:28:54.160993 1 jwt_token.go:45] token is not valid yet
E1117 09:28:54.161002 1 authentication.go:60] Unable to authenticate the request due to error: token
hongmingK零SK壹S
看起来像是这个 issue, 看看你 redis pod 正常吗, 有没有异常重启
willqyK零S
可是redis现在是正常的啊,没有任何报错日志
willqyK零S
已解决
