FeynmanK零SK贰SK壹S
linruichao 安装和基本验证与使用的步骤我看已经非常好了~ 开头部分我来润色一下吧
部署失败
370569218 kubekey的版本是多少,是不是kubekey版本不对呢? not support kubeovn 似乎是说不支持kubeovn网络插件,这一步骤还没涉及到kubeovn的安装
linruichao kubekey 需要什么版本呢
3.1.1 3.2.0 部署失败
错误信息如下
[k8smaster1 10.4.1.51] MSG:
3
ERRO[23:52:07 EST] Failed to deploy network plugin: Failed to exec command: sudo -E /bin/sh -c “/usr/local/bin/kubectl apply -f /etc/kubernetes/network-plugin.yaml”
customresourcedefinition.apiextensions.k8s.io/ips.kubeovn.io unchanged
customresourcedefinition.apiextensions.k8s.io/subnets.kubeovn.io unchanged
customresourcedefinition.apiextensions.k8s.io/vlans.kubeovn.io unchanged
podsecuritypolicy.policy/kube-ovn unchanged
configmap/ovn-config unchanged
serviceaccount/ovn unchanged
clusterrole.rbac.authorization.k8s.io/system:ovn unchanged
clusterrolebinding.rbac.authorization.k8s.io/ovn unchanged
service/ovn-nb unchanged
service/ovn-sb unchanged
error: error parsing /etc/kubernetes/network-plugin.yaml: error converting YAML to JSON: yaml: line 53: could not find expected ‘:’: Process exited with status 1 node=10.4.1.51
查看了53行,没有什么错误呢
yamllint /etc/kubernetes/network-plugin.yaml
13:7 error wrong indentation: expected 8 but found 6 (indentation)
82:7 error wrong indentation: expected 8 but found 6 (indentation)
207:7 error wrong indentation: expected 8 but found 6 (indentation)
275:15 error too many spaces after colon (colons)
399:7 error wrong indentation: expected 8 but found 6 (indentation)
425:1 error syntax error: could not find expected ‘:’ (syntax)
868:81 error line too long (101 > 80 characters) (line-length)
taoyonggang 用现在的版本可以部署成功
