安装 Kubesphere3.1.0 成功后无法访问 console 页面
- 已编辑
failed: [localhost] (item={'path': 'ks-apiserver', 'file': 'ks-apiserver.yml'}) => {"ansible_loop_var": "item", "changed": true, "cmd": ["/usr/local/bin/kubectl", "apply", "-f", "/kubesphere/kubesphere/ks-apiserver/ks-apiserver.yml", "--force"], "delta": "0:01:49.465708", "end": "2021-05-10 02:31:55.197076", "failed_when_result": true, "item": {"file": "ks-apiserver.yml", "path": "ks-apiserver"}, "msg": "non-zero return code", "rc": 1, "start": "2021-05-10 02:30:05.731368", "stderr": "error: error when creating \"/kubesphere/kubesphere/ks-apiserver/ks-apiserver.yml\": Post https://10.233.0.1:443/apis/apps/v1/namespaces/kubesphere-system/deployments: stream error: stream ID 7; INTERNAL_ERROR", "stderr_lines": ["error: error when creating \"/kubesphere/kubesphere/ks-apiserver/ks-apiserver.yml\": Post https://10.233.0.1:443/apis/apps/v1/namespaces/kubesphere-system/deployments: stream error: stream ID 7; INTERNAL_ERROR"], "stdout": "service/ks-apiserver created", "stdout_lines": ["service/ks-apiserver created"]}
changed: [localhost] => (item={'path': 'ks-controller-manager', 'file': 'ks-controller-manager.yaml'})
changed: [localhost] => (item={'path': 'ks-console', 'file': 'ks-console-config.yml'})
changed: [localhost] => (item={'path': 'ks-console', 'file': 'sample-bookinfo-configmap.yaml'})
changed: [localhost] => (item={'path': 'ks-console', 'file': 'ks-console-deployment.yml'})
localhost : ok=27 changed=21 unreachable=0 failed=1 skipped=14 rescued=0 ignored=0
CauchyK零SK壹S
进到ks-installer里apply下那个yaml试下
kubectl exec-it -n kubesphere-system $(kubectl get pod -n kubesphere-system -l app=ks-install -o jsonpath='{.items[0].metadata.name}') /bin/bash
kubectl apply -f /kubesphere/kubesphere/ks-apiserver/ks-apiserver.yml
- 已编辑
Cauchy
参数异常了
Error: unknown command "exec-it" for "kubectl"
Run 'kubectl --help' for usage.
看到kubectl exec -it
连起来了,重新执行了下 ok 了,现在进入里面执行了 yml 文件提示如下
bash-5.1$ kubectl apply -f /kubesphere/kubesphere/ks-apiserver/ks-apiserver.yml
deployment.apps/ks-apiserver created
service/ks-apiserver unchanged
- 已编辑
Cauchy
重启后出现了新的错误,连接丢失,不确定具体是什么地址丢失了
Start installing monitoring
Start installing multicluster
Start installing openpitrix
Start installing network
Waiting for all tasks to be completed ...
task multicluster status is successful (1/4)
task openpitrix status is successful (2/4)
task network status is successful (3/4)
error: http2: client connection lost
重新查看日志,发现 monitoring 启动失败
task monitoring status is failed (4/4)
Collecting installation results ...
Task 'monitoring' failed:
"counter": 75,
"created": "2021-05-10T09:29:39.402331",
"end_line": 74,
"event": "runner_on_failed",
"event_data": {
"duration": 117.614838,
"end": "2021-05-10T09:29:39.402089",
"event_loop": null,
"host": "localhost",
"ignore_errors": null,
"play": "localhost",
"play_pattern": "localhost",
"play_uuid": "42453aca-4651-eb6e-4fd2-000000000005",
"playbook": "/kubesphere/playbooks/monitoring.yaml",
"playbook_uuid": "661aa835-1511-4178-ba20-17547f31be9b",
"remote_addr": "127.0.0.1",
"res": {
"_ansible_no_log": false,
"changed": true,
"cmd": "/usr/local/bin/kubectl apply -f /kubesphere/kubesphere/prometheus/node-exporter --force",
"delta": "0:01:57.271006",
"end": "2021-05-10 05:29:39.379806",
"invocation": {
"module_args": {
"_raw_params": "/usr/local/bin/kubectl apply -f /kubesphere/kubesphere/prometheus/node-exporter --force",
"_uses_shell": true,
"argv": null,
"chdir": null,
"creates": null,
"executable": null,
"removes": null,
"stdin": null,
"stdin_add_newline": true,
"strip_empty_ends": true,
"warn": true
"rc": 1,
"start": "2021-05-10 05:27:42.108800",
"stderr": "error when retrieving current configuration of:\nResource: \"rbac.authorization.k8s.io/v1, Resource=clusterroles\", GroupVersionKind: \"rbac.authorization.k8s.io/v1, Kind=ClusterRole\"\nName: \"kubesphere-node-exporter\", Namespace: \"\"\nfrom server for: \"/kubesphere/kubesphere/prometheus/node-exporter/node-exporter-clusterRole.yaml\": Get https://10.233.0.1:443/apis/rbac.authorization.k8s.io/v1/clusterroles/kubesphere-node-exporter: http2: client connection lost\nerror when retrieving current configuration of:\nResource: \"rbac.authorization.k8s.io/v1, Resource=clusterrolebindings\", GroupVersionKind: \"rbac.authorization.k8s.io/v1, Kind=ClusterRoleBinding\"\nName: \"kubesphere-node-exporter\", Namespace: \"\"\nfrom server for: \"/kubesphere/kubesphere/prometheus/node-exporter/node-exporter-clusterRoleBinding.yaml\": Get https://10.233.0.1:443/apis/rbac.authorization.k8s.io/v1/clusterrolebindings/kubesphere-node-exporter: net/http: TLS handshake timeout\nerror when retrieving current configuration of:\nResource: \"apps/v1, Resource=daemonsets\", GroupVersionKind: \"apps/v1, Kind=DaemonSet\"\nName: \"node-exporter\", Namespace: \"kubesphere-monitoring-system\"\nfrom server for: \"/kubesphere/kubesphere/prometheus/node-exporter/node-exporter-daemonset.yaml\": Get https://10.233.0.1:443/apis/apps/v1/namespaces/kubesphere-monitoring-system/daemonsets/node-exporter: net/http: TLS handshake timeout\nerror when retrieving current configuration of:\nResource: \"/v1, Resource=services\", GroupVersionKind: \"/v1, Kind=Service\"\nName: \"node-exporter\", Namespace: \"kubesphere-monitoring-system\"\nfrom server for: \"/kubesphere/kubesphere/prometheus/node-exporter/node-exporter-service.yaml\": Get https://10.233.0.1:443/api/v1/namespaces/kubesphere-monitoring-system/services/node-exporter: net/http: TLS handshake timeout\nerror when retrieving current configuration of:\nResource: \"/v1, Resource=serviceaccounts\", GroupVersionKind: \"/v1, Kind=ServiceAccount\"\nName: \"node-exporter\", Namespace: \"kubesphere-monitoring-system\"\nfrom server for: \"/kubesphere/kubesphere/prometheus/node-exporter/node-exporter-serviceAccount.yaml\": Get https://10.233.0.1:443/api/v1/namespaces/kubesphere-monitoring-system/serviceaccounts/node-exporter: net/http: TLS handshake timeout\nerror when retrieving current configuration of:\nResource: \"monitoring.coreos.com/v1, Resource=servicemonitors\", GroupVersionKind: \"monitoring.coreos.com/v1, Kind=ServiceMonitor\"\nName: \"node-exporter\", Namespace: \"kubesphere-monitoring-system\"\nfrom server for: \"/kubesphere/kubesphere/prometheus/node-exporter/node-exporter-serviceMonitor.yaml\": Get https://10.233.0.1:443/apis/monitoring.coreos.com/v1/namespaces/kubesphere-monitoring-system/servicemonitors/node-exporter: dial tcp 10.233.0.1:443: i/o timeout",
"stderr_lines": [
"error when retrieving current configuration of:",
"Resource: \"rbac.authorization.k8s.io/v1, Resource=clusterroles\", GroupVersionKind: \"rbac.authorization.k8s.io/v1, Kind=ClusterRole\"",
"Name: \"kubesphere-node-exporter\", Namespace: \"\"",
"from server for: \"/kubesphere/kubesphere/prometheus/node-exporter/node-exporter-clusterRole.yaml\": Get https://10.233.0.1:443/apis/rbac.authorization.k8s.io/v1/clusterroles/kubesphere-node-exporter: http2: client connection lost",
"Resource: \"rbac.authorization.k8s.io/v1, Resource=clusterrolebindings\", GroupVersionKind: \"rbac.authorization.k8s.io/v1, Kind=ClusterRoleBinding\"",
"from server for: \"/kubesphere/kubesphere/prometheus/node-exporter/node-exporter-clusterRoleBinding.yaml\": Get https://10.233.0.1:443/apis/rbac.authorization.k8s.io/v1/clusterrolebindings/kubesphere-node-exporter: net/http: TLS handshake timeout",
"Resource: \"apps/v1, Resource=daemonsets\", GroupVersionKind: \"apps/v1, Kind=DaemonSet\"",
"Name: \"node-exporter\", Namespace: \"kubesphere-monitoring-system\"",
"from server for: \"/kubesphere/kubesphere/prometheus/node-exporter/node-exporter-daemonset.yaml\": Get https://10.233.0.1:443/apis/apps/v1/namespaces/kubesphere-monitoring-system/daemonsets/node-exporter: net/http: TLS handshake timeout",
"Resource: \"/v1, Resource=services\", GroupVersionKind: \"/v1, Kind=Service\"",
"from server for: \"/kubesphere/kubesphere/prometheus/node-exporter/node-exporter-service.yaml\": Get https://10.233.0.1:443/api/v1/namespaces/kubesphere-monitoring-system/services/node-exporter: net/http: TLS handshake timeout",
"Resource: \"/v1, Resource=serviceaccounts\", GroupVersionKind: \"/v1, Kind=ServiceAccount\"",
"from server for: \"/kubesphere/kubesphere/prometheus/node-exporter/node-exporter-serviceAccount.yaml\": Get https://10.233.0.1:443/api/v1/namespaces/kubesphere-monitoring-system/serviceaccounts/node-exporter: net/http: TLS handshake timeout",
"Resource: \"monitoring.coreos.com/v1, Resource=servicemonitors\", GroupVersionKind: \"monitoring.coreos.com/v1, Kind=ServiceMonitor\"",
"from server for: \"/kubesphere/kubesphere/prometheus/node-exporter/node-exporter-serviceMonitor.yaml\": Get https://10.233.0.1:443/apis/monitoring.coreos.com/v1/namespaces/kubesphere-monitoring-system/servicemonitors/node-exporter: dial tcp 10.233.0.1:443: i/o timeout"
"stdout": "",
"stdout_lines": []
"role": "ks-monitor",
"start": "2021-05-10T09:27:41.787251",
"task": "Monitoring | Installing node-exporter",
"task_action": "command",
"task_args": "",
"task_path": "/kubesphere/installer/roles/ks-monitor/tasks/node-exporter.yaml:2",
"task_uuid": "42453aca-4651-eb6e-4fd2-000000000033",
"uuid": "7213fbbc-9a99-4995-8c76-c7d45a908a11"
"parent_uuid": "42453aca-4651-eb6e-4fd2-000000000033",
"pid": 3959,
"runner_ident": "monitoring",
"start_line": 73,
"stdout": "fatal: [localhost]: FAILED! => {\"changed\": true, \"cmd\": \"/usr/local/bin/kubectl apply -f /kubesphere/kubesphere/prometheus/node-exporter --force\", \"delta\": \"0:01:57.271006\", \"end\": \"2021-05-10 05:29:39.379806\", \"msg\": \"non-zero return code\", \"rc\": 1, \"start\": \"2021-05-10 05:27:42.108800\", \"stderr\": \"error when retrieving current configuration of:\\nResource: \\\"rbac.authorization.k8s.io/v1, Resource=clusterroles\\\", GroupVersionKind: \\\"rbac.authorization.k8s.io/v1, Kind=ClusterRole\\\"\\nName: \\\"kubesphere-node-exporter\\\", Namespace: \\\"\\\"\\nfrom server for: \\\"/kubesphere/kubesphere/prometheus/node-exporter/node-exporter-clusterRole.yaml\\\": Get https://10.233.0.1:443/apis/rbac.authorization.k8s.io/v1/clusterroles/kubesphere-node-exporter: http2: client connection lost\\nerror when retrieving current configuration of:\\nResource: \\\"rbac.authorization.k8s.io/v1, Resource=clusterrolebindings\\\", GroupVersionKind: \\\"rbac.authorization.k8s.io/v1, Kind=ClusterRoleBinding\\\"\\nName: \\\"kubesphere-node-exporter\\\", Namespace: \\\"\\\"\\nfrom server for: \\\"/kubesphere/kubesphere/prometheus/node-exporter/node-exporter-clusterRoleBinding.yaml\\\": Get https://10.233.0.1:443/apis/rbac.authorization.k8s.io/v1/clusterrolebindings/kubesphere-node-exporter: net/http: TLS handshake timeout\\nerror when retrieving current configuration of:\\nResource: \\\"apps/v1, Resource=daemonsets\\\", GroupVersionKind: \\\"apps/v1, Kind=DaemonSet\\\"\\nName: \\\"node-exporter\\\", Namespace: \\\"kubesphere-monitoring-system\\\"\\nfrom server for: \\\"/kubesphere/kubesphere/prometheus/node-exporter/node-exporter-daemonset.yaml\\\": Get https://10.233.0.1:443/apis/apps/v1/namespaces/kubesphere-monitoring-system/daemonsets/node-exporter: net/http: TLS handshake timeout\\nerror when retrieving current configuration of:\\nResource: \\\"/v1, Resource=services\\\", GroupVersionKind: \\\"/v1, Kind=Service\\\"\\nName: \\\"node-exporter\\\", Namespace: \\\"kubesphere-monitoring-system\\\"\\nfrom server for: \\\"/kubesphere/kubesphere/prometheus/node-exporter/node-exporter-service.yaml\\\": Get https://10.233.0.1:443/api/v1/namespaces/kubesphere-monitoring-system/services/node-exporter: net/http: TLS handshake timeout\\nerror when retrieving current configuration of:\\nResource: \\\"/v1, Resource=serviceaccounts\\\", GroupVersionKind: \\\"/v1, Kind=ServiceAccount\\\"\\nName: \\\"node-exporter\\\", Namespace: \\\"kubesphere-monitoring-system\\\"\\nfrom server for: \\\"/kubesphere/kubesphere/prometheus/node-exporter/node-exporter-serviceAccount.yaml\\\": Get https://10.233.0.1:443/api/v1/namespaces/kubesphere-monitoring-system/serviceaccounts/node-exporter: net/http: TLS handshake timeout\\nerror when retrieving current configuration of:\\nResource: \\\"monitoring.coreos.com/v1, Resource=servicemonitors\\\", GroupVersionKind: \\\"monitoring.coreos.com/v1, Kind=ServiceMonitor\\\"\\nName: \\\"node-exporter\\\", Namespace: \\\"kubesphere-monitoring-system\\\"\\nfrom server for: \\\"/kubesphere/kubesphere/prometheus/node-exporter/node-exporter-serviceMonitor.yaml\\\": Get https://10.233.0.1:443/apis/monitoring.coreos.com/v1/namespaces/kubesphere-monitoring-system/servicemonitors/node-exporter: dial tcp 10.233.0.1:443: i/o timeout\", \"stderr_lines\": [\"error when retrieving current configuration of:\", \"Resource: \\\"rbac.authorization.k8s.io/v1, Resource=clusterroles\\\", GroupVersionKind: \\\"rbac.authorization.k8s.io/v1, Kind=ClusterRole\\\"\", \"Name: \\\"kubesphere-node-exporter\\\", Namespace: \\\"\\\"\", \"from server for: \\\"/kubesphere/kubesphere/prometheus/node-exporter/node-exporter-clusterRole.yaml\\\": Get https://10.233.0.1:443/apis/rbac.authorization.k8s.io/v1/clusterroles/kubesphere-node-exporter: http2: client connection lost\", \"error when retrieving current configuration of:\", \"Resource: \\\"rbac.authorization.k8s.io/v1, Resource=clusterrolebindings\\\", GroupVersionKind: \\\"rbac.authorization.k8s.io/v1, Kind=ClusterRoleBinding\\\"\", \"Name: \\\"kubesphere-node-exporter\\\", Namespace: \\\"\\\"\", \"from server for: \\\"/kubesphere/kubesphere/prometheus/node-exporter/node-exporter-clusterRoleBinding.yaml\\\": Get https://10.233.0.1:443/apis/rbac.authorization.k8s.io/v1/clusterrolebindings/kubesphere-node-exporter: net/http: TLS handshake timeout\", \"error when retrieving current configuration of:\", \"Resource: \\\"apps/v1, Resource=daemonsets\\\", GroupVersionKind: \\\"apps/v1, Kind=DaemonSet\\\"\", \"Name: \\\"node-exporter\\\", Namespace: \\\"kubesphere-monitoring-system\\\"\", \"from server for: \\\"/kubesphere/kubesphere/prometheus/node-exporter/node-exporter-daemonset.yaml\\\": Get https://10.233.0.1:443/apis/apps/v1/namespaces/kubesphere-monitoring-system/daemonsets/node-exporter: net/http: TLS handshake timeout\", \"error when retrieving current configuration of:\", \"Resource: \\\"/v1, Resource=services\\\", GroupVersionKind: \\\"/v1, Kind=Service\\\"\", \"Name: \\\"node-exporter\\\", Namespace: \\\"kubesphere-monitoring-system\\\"\", \"from server for: \\\"/kubesphere/kubesphere/prometheus/node-exporter/node-exporter-service.yaml\\\": Get https://10.233.0.1:443/api/v1/namespaces/kubesphere-monitoring-system/services/node-exporter: net/http: TLS handshake timeout\", \"error when retrieving current configuration of:\", \"Resource: \\\"/v1, Resource=serviceaccounts\\\", GroupVersionKind: \\\"/v1, Kind=ServiceAccount\\\"\", \"Name: \\\"node-exporter\\\", Namespace: \\\"kubesphere-monitoring-system\\\"\", \"from server for: \\\"/kubesphere/kubesphere/prometheus/node-exporter/node-exporter-serviceAccount.yaml\\\": Get https://10.233.0.1:443/api/v1/namespaces/kubesphere-monitoring-system/serviceaccounts/node-exporter: net/http: TLS handshake timeout\", \"error when retrieving current configuration of:\", \"Resource: \\\"monitoring.coreos.com/v1, Resource=servicemonitors\\\", GroupVersionKind: \\\"monitoring.coreos.com/v1, Kind=ServiceMonitor\\\"\", \"Name: \\\"node-exporter\\\", Namespace: \\\"kubesphere-monitoring-system\\\"\", \"from server for: \\\"/kubesphere/kubesphere/prometheus/node-exporter/node-exporter-serviceMonitor.yaml\\\": Get https://10.233.0.1:443/apis/monitoring.coreos.com/v1/namespaces/kubesphere-monitoring-system/servicemonitors/node-exporter: dial tcp 10.233.0.1:443: i/o timeout\"], \"stdout\": \"\", \"stdout_lines\": []}",
Failed to ansible-playbook ks-config.yaml
E0510 05:36:26.988333 1 reflector.go:284] pkg/mod/k8s.io/client-go@v0.0.0-20190411052641-7a6b4715b709/tools/cache/reflector.go:99: Failed to watch *unstructured.Unstructured: Get "https://10.233.0.1:443/apis/installer.kubesphere.io/v1alpha1/namespaces/kubesphere-system/clusterconfigurations?fieldSelector=metadata.name%3Dks-installer&resourceVersion=48786&timeoutSeconds=499&watch=true": dial tcp 10.233.0.1:443: connect: connection refused
E0510 05:36:27.990356 1 reflector.go:131] pkg/mod/k8s.io/client-go@v0.0.0-20190411052641-7a6b4715b709/tools/cache/reflector.go:99: Failed to list *unstructured.Unstructured: Get "https://10.233.0.1:443/apis/installer.kubesphere.io/v1alpha1/namespaces/kubesphere-system/clusterconfigurations?fieldSelector=metadata.name%3Dks-installer&limit=500&resourceVersion=0": dial tcp 10.233.0.1:443: connect: connection refused
E0510 05:36:28.991146 1 reflector.go:131] pkg/mod/k8s.io/client-go@v0.0.0-20190411052641-7a6b4715b709/tools/cache/reflector.go:99: Failed to list *unstructured.Unstructured: Get "https://10.233.0.1:443/apis/installer.kubesphere.io/v1alpha1/namespaces/kubesphere-system/clusterconfigurations?fieldSelector=metadata.name%3Dks-installer&limit=500&resourceVersion=0": dial tcp 10.233.0.1:443: connect: connection refused
E0510 05:36:29.991965 1 reflector.go:131] pkg/mod/k8s.io/client-go@v0.0.0-20190411052641-7a6b4715b709/tools/cache/reflector.go:99: Failed to list *unstructured.Unstructured: Get "https://10.233.0.1:443/apis/installer.kubesphere.io/v1alpha1/namespaces/kubesphere-system/clusterconfigurations?fieldSelector=metadata.name%3Dks-installer&limit=500&resourceVersion=0": dial tcp 10.233.0.1:443: connect: connection refused
E0510 05:36:30.992636 1 reflector.go:131] pkg/mod/k8s.io/client-go@v0.0.0-20190411052641-7a6b4715b709/tools/cache/reflector.go:99: Failed to list *unstructured.Unstructured: Get "https://10.233.0.1:443/apis/installer.kubesphere.io/v1alpha1/namespaces/kubesphere-system/clusterconfigurations?fieldSelector=metadata.name%3Dks-installer&limit=500&resourceVersion=0": dial tcp 10.233.0.1:443: connect: connection refused
E0510 05:36:31.993368 1 reflector.go:131] pkg/mod/k8s.io/client-go@v0.0.0-20190411052641-7a6b4715b709/tools/cache/reflector.go:99: Failed to list *unstructured.Unstructured: Get "https://10.233.0.1:443/apis/installer.kubesphere.io/v1alpha1/namespaces/kubesphere-system/clusterconfigurations?fieldSelector=metadata.name%3Dks-installer&limit=500&resourceVersion=0": dial tcp 10.233.0.1:443: connect: connection refused
E0510 05:36:32.994235 1 reflector.go:131] pkg/mod/k8s.io/client-go@v0.0.0-20190411052641-7a6b4715b709/tools/cache/reflector.go:99: Failed to list *unstructured.Unstructured: Get "https://10.233.0.1:443/apis/installer.kubesphere.io/v1alpha1/namespaces/kubesphere-system/clusterconfigurations?fieldSelector=metadata.name%3Dks-installer&limit=500&resourceVersion=0": dial tcp 10.233.0.1:443: connect: connection refused
E0510 05:36:33.998121 1 reflector.go:131] pkg/mod/k8s.io/client-go@v0.0.0-20190411052641-7a6b4715b709/tools/cache/reflector.go:99: Failed to list *unstructured.Unstructured: Get "https://10.233.0.1:443/apis/installer.kubesphere.io/v1alpha1/namespaces/kubesphere-system/clusterconfigurations?fieldSelector=metadata.name%3Dks-installer&limit=500&resourceVersion=0": dial tcp 10.233.0.1:443: connect: connection refused
E0510 05:36:34.998777 1 reflector.go:131] pkg/mod/k8s.io/client-go@v0.0.0-20190411052641-7a6b4715b709/tools/cache/reflector.go:99: Failed to list *unstructured.Unstructured: Get "https://10.233.0.1:443/apis/installer.kubesphere.io/v1alpha1/namespaces/kubesphere-system/clusterconfigurations?fieldSelector=metadata.name%3Dks-installer&limit=500&resourceVersion=0": dial tcp 10.233.0.1:443: connect: connection refused
E0510 05:36:35.999464 1 reflector.go:131] pkg/mod/k8s.io/client-go@v0.0.0-20190411052641-7a6b4715b709/tools/cache/reflector.go:99: Failed to list *unstructured.Unstructured: Get "https://10.233.0.1:443/apis/installer.kubesphere.io/v1alpha1/namespaces/kubesphere-system/clusterconfigurations?fieldSelector=metadata.name%3Dks-installer&limit=500&resourceVersion=0": dial tcp 10.233.0.1:443: connect: connection refused
E0510 05:36:37.000144 1 reflector.go:131] pkg/mod/k8s.io/client-go@v0.0.0-20190411052641-7a6b4715b709/tools/cache/reflector.go:99: Failed to list *unstructured.Unstructured: Get "https://10.233.0.1:443/apis/installer.kubesphere.io/v1alpha1/namespaces/kubesphere-system/clusterconfigurations?fieldSelector=metadata.name%3Dks-installer&limit=500&resourceVersion=0": dial tcp 10.233.0.1:443: connect: connection refused
E0510 05:36:38.000891 1 reflector.go:131] pkg/mod/k8s.io/client-go@v0.0.0-20190411052641-7a6b4715b709/tools/cache/reflector.go:99: Failed to list *unstructured.Unstructured: Get "https://10.233.0.1:443/apis/installer.kubesphere.io/v1alpha1/namespaces/kubesphere-system/clusterconfigurations?fieldSelector=metadata.name%3Dks-installer&limit=500&resourceVersion=0": dial tcp 10.233.0.1:443: connect: connection refused
E0510 05:36:39.001655 1 reflector.go:131] pkg/mod/k8s.io/client-go@v0.0.0-20190411052641-7a6b4715b709/tools/cache/reflector.go:99: Failed to list *unstructured.Unstructured: Get "https://10.233.0.1:443/apis/installer.kubesphere.io/v1alpha1/namespaces/kubesphere-system/clusterconfigurations?fieldSelector=metadata.name%3Dks-installer&limit=500&resourceVersion=0": dial tcp 10.233.0.1:443: connect: connection refused
E0510 05:36:40.002446 1 reflector.go:131] pkg/mod/k8s.io/client-go@v0.0.0-20190411052641-7a6b4715b709/tools/cache/reflector.go:99: Failed to list *unstructured.Unstructured: Get "https://10.233.0.1:443/apis/installer.kubesphere.io/v1alpha1/namespaces/kubesphere-system/clusterconfigurations?fieldSelector=metadata.name%3Dks-installer&limit=500&resourceVersion=0": dial tcp 10.233.0.1:443: connect: connection refused
E0510 05:36:41.003137 1 reflector.go:131] pkg/mod/k8s.io/client-go@v0.0.0-20190411052641-7a6b4715b709/tools/cache/reflector.go:99: Failed to list *unstructured.Unstructured: Get "https://10.233.0.1:443/apis/installer.kubesphere.io/v1alpha1/namespaces/kubesphere-system/clusterconfigurations?fieldSelector=metadata.name%3Dks-installer&limit=500&resourceVersion=0": dial tcp 10.233.0.1:443: connect: connection refused
E0510 05:36:42.005667 1 reflector.go:131] pkg/mod/k8s.io/client-go@v0.0.0-20190411052641-7a6b4715b709/tools/cache/reflector.go:99: Failed to list *unstructured.Unstructured: Get "https://10.233.0.1:443/apis/installer.kubesphere.io/v1alpha1/namespaces/kubesphere-system/clusterconfigurations?fieldSelector=metadata.name%3Dks-installer&limit=500&resourceVersion=0": dial tcp 10.233.0.1:443: connect: connection refused
- 已编辑
Cauchy
现在已经安装成功,提示我访问 30880 的 web 端
但是访问不了,连接超时是为什么呢
用 telnet 能够连接的上,服务器资源也还够 CPU 使用了 6%,内存只用了 2G
我服务器有 16G 内存,6核 CPU,120G 硬盘
防火墙已经全部关闭 telnet 可以访问 curl 访问不了
pod 信息
ks-apiserver-7d4f466f75-5wc5v 1/1 Running 0 29m
ks-console-5576fccbb8-4mqpt 1/1 Running 0 20h
ks-controller-manager-7d9b98f467-r2km6 1/1 Running 0 29m
ks-installer-8d7b5cfc4-lkffh 1/1 Running 0 32m
NAMESPACE NAME READY STATUS RESTARTS AGE IP NODE NOMINATED NODE READINESS GATES
kube-system calico-kube-controllers-8545b68dd4-8bzjr 1/1 Running 0 22h 10.233.90.1 node1 <none> <none>
kube-system calico-node-bhf2k 1/1 Running 0 22h 192.168.113.121 node1 <none> <none>
kube-system calico-node-k2r5k 1/1 Running 1 22h 192.168.113.120 master1 <none> <none>
kube-system calico-node-t7dbs 1/1 Running 0 22h 192.168.113.122 node2 <none> <none>
kube-system coredns-867b49865c-krk2l 1/1 Running 1 22h 10.233.97.5 master1 <none> <none>
kube-system coredns-867b49865c-txt7n 1/1 Running 1 22h 10.233.97.4 master1 <none> <none>
kube-system init-pvc-1dcd1a64-38c6-4250-8043-1f91ccc025a5 0/1 Completed 0 17h 10.233.96.4 node2 <none> <none>
kube-system init-pvc-c6e7bfc1-5485-4a59-89d8-691015562d39 0/1 Completed 0 17h 10.233.90.8 node1 <none> <none>
kube-system kube-apiserver-master1 1/1 Running 2 22h 192.168.113.120 master1 <none> <none>
kube-system kube-controller-manager-master1 1/1 Running 6 22h 192.168.113.120 master1 <none> <none>
kube-system kube-proxy-dj8nx 1/1 Running 1 22h 192.168.113.120 master1 <none> <none>
kube-system kube-proxy-mqmgw 1/1 Running 0 22h 192.168.113.121 node1 <none> <none>
kube-system kube-proxy-qhxwt 1/1 Running 0 22h 192.168.113.122 node2 <none> <none>
kube-system kube-scheduler-master1 1/1 Running 5 22h 192.168.113.120 master1 <none> <none>
kube-system nodelocaldns-bkdlp 1/1 Running 0 22h 192.168.113.122 node2 <none> <none>
kube-system nodelocaldns-rsdn6 1/1 Running 0 22h 192.168.113.121 node1 <none> <none>
kube-system nodelocaldns-xkl8q 1/1 Running 1 22h 192.168.113.120 master1 <none> <none>
kube-system openebs-localpv-provisioner-c46f4fbd5-ntkw8 1/1 Running 57 20h 10.233.96.1 node2 <none> <none>
kube-system snapshot-controller-0 1/1 Running 0 20h 10.233.96.2 node2 <none> <none>
kubesphere-controls-system default-http-backend-76d9fb4bb7-pkkl7 1/1 Running 0 20h 10.233.90.4 node1 <none> <none>
kubesphere-controls-system kubectl-admin-7b69cb97d5-6brvg 1/1 Running 0 13h 10.233.90.12 node1 <none> <none>
kubesphere-monitoring-system alertmanager-main-0 2/2 Running 0 17h 10.233.90.9 node1 <none> <none>
kubesphere-monitoring-system alertmanager-main-1 2/2 Running 0 17h 10.233.96.5 node2 <none> <none>
kubesphere-monitoring-system alertmanager-main-2 2/2 Running 0 17h 10.233.96.6 node2 <none> <none>
kubesphere-monitoring-system kube-state-metrics-687c7c4d86-nb4d4 3/3 Running 2 17h 10.233.90.7 node1 <none> <none>
kubesphere-monitoring-system node-exporter-525tt 2/2 Running 0 17h 192.168.113.121 node1 <none> <none>
kubesphere-monitoring-system node-exporter-7dqgb 2/2 Running 0 17h 192.168.113.122 node2 <none> <none>
kubesphere-monitoring-system node-exporter-vgrhq 2/2 Running 0 17h 192.168.113.120 master1 <none> <none>
kubesphere-monitoring-system notification-manager-deployment-7bd887ffb4-pwjg8 1/1 Running 0 13h 10.233.90.13 node1 <none> <none>
kubesphere-monitoring-system notification-manager-deployment-7bd887ffb4-vxhrp 1/1 Running 0 13h 10.233.96.8 node2 <none> <none>
kubesphere-monitoring-system notification-manager-operator-78595d8666-d9vfn 2/2 Running 1 13h 10.233.90.11 node1 <none> <none>
kubesphere-monitoring-system prometheus-k8s-0 0/3 Pending 0 17h <none> <none> <none> <none>
kubesphere-monitoring-system prometheus-k8s-1 0/3 Pending 0 17h <none> <none> <none> <none>
kubesphere-monitoring-system prometheus-operator-d7fdfccbf-7p2pv 2/2 Running 0 17h 10.233.96.3 node2 <none> <none>
kubesphere-system ks-apiserver-7d4f466f75-5wc5v 1/1 Running 0 29m 10.233.97.8 master1 <none> <none>
kubesphere-system ks-console-5576fccbb8-4mqpt 1/1 Running 0 20h 10.233.90.3 node1 <none> <none>
kubesphere-system ks-controller-manager-7d9b98f467-r2km6 1/1 Running 0 29m 10.233.97.9 master1 <none> <none>
kubesphere-system ks-installer-8d7b5cfc4-lkffh 1/1 Running 0 33m 10.233.90.15 node1 <none> <none>
- 已编辑
重装了一次,成功了但还是访问不了,都是 telnet 可以 curl 不可以
Cauchy @Jeff
### Welcome to KubeSphere! ###
Console: http://192.168.113.120:30880
Account: admin
Password: P@88w0rd
NOTES:
1. After you log into the console, please check the
monitoring status of service components in
"Cluster Management". If any service is not
ready, please wait patiently until all components
are up and running.
2. Please change the default password after login.
https://kubesphere.io 2021-05-11 12:06:41
pod 信息
[root@master1 kubesphere]# kubectl get pods -n kubesphere-system
ks-apiserver-75958c7c85-wqdkr 1/1 Running 0 27m
ks-console-5576fccbb8-ssgqs 1/1 Running 0 29m
ks-controller-manager-fb858c67b-gsv29 1/1 Running 3 27m
ks-installer-7fb74c656c-8887s 1/1 Running 0 34m
minio-f69748945-j7qhm 1/1 Running 0 31m
openldap-0 1/1 Running 1 31m
openpitrix-import-job-kc22l 0/1 Completed 0 29m
redis-658988fc5b-rfnnf 1/1 Running 0 32m
`clusterconfiguration.installer.kubesphere.io/ks-installer unchanged
WARN[17:35:42 HKT] Task failed …
WARN[17:35:42 HKT] error: KubeSphere startup timeout.
Error: Failed to deploy kubesphere: KubeSphere startup timeout.
Usage:
kk create cluster [flags]
Flags:
–download-cmd string The user defined command to download the necessary binary files. The first param ‘%s’ is output path, the second param ‘%s’, is the URL (default “curl -L -o %s %s”)
-f, –filename string Path to a configuration file
-h, –help help for cluster
–skip-pull-images Skip pre pull images
–with-kubernetes string Specify a supported version of kubernetes (default “v1.19.8”)
–with-kubesphere Deploy a specific version of kubesphere (default v3.1.0)
–with-local-storage Deploy a local PV provisioner
-y, –yes Skip pre-check of the installation
Global Flags:
–debug Print detailed information (default true)
–in-cluster Running inside the cluster
Failed to deploy kubesphere: KubeSphere startup timeout.`
同样的问题 Failed to deploy kubesphere: KubeSphere startup timeout.
我也是,怎么解决的呢
是否被防火墙拦住了,看看防火墙关了没
- 已编辑
可能是内存不足,重启一下docker试试
