目前
缺少event-exportor
查看ks-events-operator日志也没看到明显报错
bglab@master:~$ kubectl -n kubesphere-logging-system logs ks-events-operator-6b7998ddc9-pfldf
2021-06-01T16:56:12.486+0800 INFO controller-runtime.metrics metrics server is starting to listen {"addr": ":8080"}
2021-06-01T16:56:12.486+0800 INFO controller-runtime.builder Registering a mutating webhook {"GVK": "events.kubesphere.io/v1alpha1, Kind=Rule", "path": "/mutate-events-kubesphere-io-v1alpha1-rule"}
2021-06-01T16:56:12.486+0800 INFO controller-runtime.webhook registering webhook {"path": "/mutate-events-kubesphere-io-v1alpha1-rule"}
2021-06-01T16:56:12.486+0800 INFO controller-runtime.builder Registering a validating webhook {"GVK": "events.kubesphere.io/v1alpha1, Kind=Rule", "path": "/validate-events-kubesphere-io-v1alpha1-rule"}
2021-06-01T16:56:12.486+0800 INFO controller-runtime.webhook registering webhook {"path": "/validate-events-kubesphere-io-v1alpha1-rule"}
2021-06-01T16:56:12.486+0800 INFO setup starting manager
2021-06-01T16:56:12.487+0800 INFO controller-runtime.webhook.webhooks starting webhook server
2021-06-01T16:56:12.487+0800 INFO controller-runtime.manager starting metrics server {"path": "/metrics"}
2021-06-01T16:56:12.487+0800 INFO controller-runtime.controller Starting EventSource {"controller": "ruler", "source": "kind source: /, Kind="}
2021-06-01T16:56:12.487+0800 INFO controller-runtime.controller Starting EventSource {"controller": "exporter", "source": "kind source: /, Kind="}
2021-06-01T16:56:12.487+0800 INFO controller-runtime.controller Starting EventSource {"controller": "rule", "source": "kind source: /, Kind="}
2021-06-01T16:56:12.487+0800 INFO controller-runtime.certwatcher Updated current TLS certificate
2021-06-01T16:56:12.487+0800 INFO controller-runtime.webhook serving webhook server {"host": "", "port": 9443}
2021-06-01T16:56:12.487+0800 INFO controller-runtime.certwatcher Starting certificate watcher
2021-06-01T16:56:12.587+0800 INFO controller-runtime.controller Starting EventSource {"controller": "ruler", "source": "kind source: /, Kind="}
2021-06-01T16:56:12.587+0800 INFO controller-runtime.controller Starting Controller {"controller": "rule"}
2021-06-01T16:56:12.588+0800 INFO controller-runtime.controller Starting EventSource {"controller": "exporter", "source": "kind source: /, Kind="}
2021-06-01T16:56:12.687+0800 INFO controller-runtime.controller Starting workers {"controller": "rule", "worker count": 1}
2021-06-01T16:56:12.687+0800 INFO controller-runtime.controller Starting EventSource {"controller": "ruler", "source": "kind source: /, Kind="}
2021-06-01T16:56:12.729+0800 INFO controller-runtime.controller Starting EventSource {"controller": "exporter", "source": "kind source: /, Kind="}
2021-06-01T16:56:12.830+0800 INFO controller-runtime.controller Starting EventSource {"controller": "ruler", "source": "kind source: /, Kind="}
2021-06-01T16:56:13.130+0800 INFO controller-runtime.controller Starting EventSource {"controller": "exporter", "source": "kind source: /, Kind="}
2021-06-01T16:56:13.131+0800 INFO controller-runtime.controller Starting EventSource {"controller": "ruler", "source": "kind source: /, Kind="}
2021-06-01T16:56:13.231+0800 INFO controller-runtime.controller Starting EventSource {"controller": "exporter", "source": "kind source: /, Kind="}
2021-06-01T16:56:13.231+0800 INFO controller-runtime.controller Starting EventSource {"controller": "ruler", "source": "kind source: /, Kind="}
2021-06-01T16:56:13.331+0800 INFO controller-runtime.controller Starting EventSource {"controller": "ruler", "source": "kind source: /, Kind="}
2021-06-01T16:56:13.331+0800 INFO controller-runtime.controller Starting EventSource {"controller": "exporter", "source": "kind source: /, Kind="}
2021-06-01T16:56:13.432+0800 INFO controller-runtime.controller Starting Controller {"controller": "ruler"}
2021-06-01T16:56:13.432+0800 INFO controller-runtime.controller Starting workers {"controller": "ruler", "worker count": 1}
2021-06-01T16:56:13.432+0800 INFO controller-runtime.controller Starting Controller {"controller": "exporter"}
2021-06-01T16:56:13.432+0800 INFO controller-runtime.controller Starting workers {"controller": "exporter", "worker count": 1}
2021-06-01T16:56:13.440+0800 DEBUG controller-runtime.controller Successfully Reconciled {"controller": "ruler", "request": "kubesphere-logging-system/ks-events-ruler"}
bglab@csz711#25534 缺少event-exportor
