pipeline 一直在队列中,错误如下:
`Events:
Type Reason Age From Message
Normal Scheduled 5s default-scheduler Successfully assigned kubesphere-devops-system/base-tv48w to minikube
Normal Pulled 4s kubelet Container image “jenkins/jnlp-slave:3.27-1” already present on machine
Normal Created 4s kubelet Created container jnlp
Normal Started 4s kubelet Started container jnlp
Normal Pulled 4s kubelet Container image “kubesphere/builder-base:v3.1.0” already present on machine
Normal Created 4s kubelet Created container base
Warning Failed 4s kubelet Error: failed to start container “base”: Error response from daemon: OCI runtime create failed: container_linux.go:367: starting container process caused: process_linux.go:495: container init caused: process_linux.go:458: setting cgroup config for procHooks process caused: failed to write “400000”: write /sys/fs/cgroup/cpu,cpuacct/kubepods/burstable/pod62ff6d42-9efd-4431-9ae4-370859d92456/base/cpu.cfs_quota_us: invalid argument: unknown
Normal Killing 1s kubelet Stopping container jnlp`
这种一般是啥问题呢
