kubesphere版本号是2.1.1的,已经稳定跑了一年了,今天要更新点东西,突然发现最后流水线最后一步报错,日志如下:
`Starting Kubernetes deployment
Loading configuration: /home/jenkins/agent/workspace/roject-63nP5mywmz44_king_product/deploy/deployment-king-apiservice.yaml
ERROR: ERROR: java.lang.RuntimeException: io.kubernetes.client.openapi.ApiException: Unauthorized
hudson.remoting.ProxyException: java.lang.RuntimeException: io.kubernetes.client.openapi.ApiException: Unauthorized
at com.microsoft.jenkins.kubernetes.wrapper.ResourceManager.handleApiExceptionExceptNotFound(ResourceManager.java:180)
at com.microsoft.jenkins.kubernetes.wrapper.V1ResourceManager$DeploymentUpdater.getCurrentResource(V1ResourceManager.java:213)
at com.microsoft.jenkins.kubernetes.wrapper.V1ResourceManager$DeploymentUpdater.getCurrentResource(V1ResourceManager.java:201)
at com.microsoft.jenkins.kubernetes.wrapper.ResourceManager$ResourceUpdater.createOrApply(ResourceManager.java:93)
at com.microsoft.jenkins.kubernetes.wrapper.KubernetesClientWrapper.handleResource(KubernetesClientWrapper.java:289)
at com.microsoft.jenkins.kubernetes.wrapper.KubernetesClientWrapper.apply(KubernetesClientWrapper.java:256)
at com.microsoft.jenkins.kubernetes.command.DeploymentCommand$DeploymentTask.doCall(DeploymentCommand.java:172)
at com.microsoft.jenkins.kubernetes.command.DeploymentCommand$DeploymentTask.call(DeploymentCommand.java:124)
at com.microsoft.jenkins.kubernetes.command.DeploymentCommand$DeploymentTask.call(DeploymentCommand.java:106)
at hudson.remoting.UserRequest.perform(UserRequest.java:212)
at hudson.remoting.UserRequest.perform(UserRequest.java:54)
at hudson.remoting.Request$2.run(Request.java:369)
at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:72)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at hudson.remoting.Engine$1.lambda$newThread$0(Engine.java:93)
at java.lang.Thread.run(Thread.java:748)
Suppressed: hudson.remoting.Channel$CallSiteStackTrace: Remote call to JNLP4-connect connection from 172.20.2.81/172.20.2.81:44186
at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1743)
at hudson.remoting.UserRequest$ExceptionResponse.retrieve(UserRequest.java:357)
at hudson.remoting.Channel.call(Channel.java:957)
at hudson.FilePath.act(FilePath.java:1160)
at com.microsoft.jenkins.kubernetes.command.DeploymentCommand.execute(DeploymentCommand.java:68)
at com.microsoft.jenkins.kubernetes.command.DeploymentCommand.execute(DeploymentCommand.java:45)
at com.microsoft.jenkins.azurecommons.command.CommandService.runCommand(CommandService.java:88)
at com.microsoft.jenkins.azurecommons.command.CommandService.execute(CommandService.java:96)
at com.microsoft.jenkins.azurecommons.command.CommandService.executeCommands(CommandService.java:75)
at com.microsoft.jenkins.azurecommons.command.BaseCommandContext.executeCommands(BaseCommandContext.java:77)
at com.microsoft.jenkins.kubernetes.KubernetesDeploy.perform(KubernetesDeploy.java:42)
at com.microsoft.jenkins.azurecommons.command.SimpleBuildStepExecution.run(SimpleBuildStepExecution.java:54)
at com.microsoft.jenkins.azurecommons.command.SimpleBuildStepExecution.run(SimpleBuildStepExecution.java:35)
at org.jenkinsci.plugins.workflow.steps.SynchronousNonBlockingStepExecution.lambda$start$0(SynchronousNonBlockingStepExecution.java:47)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
… 1 more
Caused by: hudson.remoting.ProxyException: io.kubernetes.client.openapi.ApiException: Unauthorized
at io.kubernetes.client.openapi.ApiClient.handleResponse(ApiClient.java:979)
at io.kubernetes.client.openapi.ApiClient.execute(ApiClient.java:895)
at io.kubernetes.client.openapi.apis.AppsV1Api.readNamespacedDeploymentWithHttpInfo(AppsV1Api.java:7299)
at io.kubernetes.client.openapi.apis.AppsV1Api.readNamespacedDeployment(AppsV1Api.java:7275)
at com.microsoft.jenkins.kubernetes.wrapper.V1ResourceManager$DeploymentUpdater.getCurrentResource(V1ResourceManager.java:210)
… 16 more
Api call failed with code 401, detailed message: {
“kind”: “Status”,
“apiVersion”: “v1”,
“metadata”: {
“status”: “Failure”,
“message”: “Unauthorized”,
“reason”: “Unauthorized”,
“code”: 401
Kubernetes deployment ended with HasError`
之前都是好好的,也没做啥升级,为啥突然变这样了;看了其他同学的帖子也没发现相似的,各位大神帮看一下,谢谢
