[root@master-01 ~]# kubectl describe pod kube-apiserver-master-01 -n kube-system
Namespace: kube-system
Priority: 2000001000
Priority Class Name: system-node-critical
Node: master-01/192.168.115.43
Start Time: Wed, 24 Nov 2021 13:58:59 +0800
Labels: component=kube-apiserver
tier=control-plane
Annotations: kubeadm.kubernetes.io/kube-apiserver.advertise-address.endpoint: 192.168.115.43:6443
kubernetes.io/config.hash: af3ae564ed03c42664956c889e8a4a1b
kubernetes.io/config.mirror: af3ae564ed03c42664956c889e8a4a1b
kubernetes.io/config.seen: 2021-12-31T14:22:02.232516340+08:00
kubernetes.io/config.source: file
Status: Running
IP: 192.168.115.43
IPs:
IP: 192.168.115.43
Controlled By: Node/master-01
Containers:
kube-apiserver:
Container ID: docker://8bd1e2a57df48c1bbc2b3cc49dfccd1078222d05c3e5796a7e426938f607f1f1
Image: registry.cn-beijing.aliyuncs.com/kubesphereio/kube-apiserver:v1.21.5
Image ID: docker-pullable://registry.cn-beijing.aliyuncs.com/kubesphereio/kube-apiserver@sha256:2a88e173873a9870bea873f3907557aefee3fe6887859b648cea06a38fa08227
Port: <none>
Host Port: <none>
Command:
kube-apiserver
--advertise-address=192.168.115.43
--allow-privileged=true
--audit-log-maxage=30
--audit-log-maxbackup=10
--audit-log-maxsize=100
--authorization-mode=Node,RBAC
--bind-address=0.0.0.0
--client-ca-file=/etc/kubernetes/pki/ca.crt
--enable-admission-plugins=NodeRestriction
--enable-bootstrap-token-auth=true
--etcd-cafile=/etc/ssl/etcd/ssl/ca.pem
--etcd-certfile=/etc/ssl/etcd/ssl/node-master-01.pem
--etcd-keyfile=/etc/ssl/etcd/ssl/node-master-01-key.pem
--etcd-servers=https://192.168.115.43:2379,https://192.168.115.44:2379,https://192.168.115.45:2379
--feature-gates=ExpandCSIVolumes=true,RotateKubeletServerCertificate=true
--insecure-port=0
--kubelet-client-certificate=/etc/kubernetes/pki/apiserver-kubelet-client.crt
--kubelet-client-key=/etc/kubernetes/pki/apiserver-kubelet-client.key
--kubelet-preferred-address-types=InternalIP,ExternalIP,Hostname
--proxy-client-cert-file=/etc/kubernetes/pki/front-proxy-client.crt
--proxy-client-key-file=/etc/kubernetes/pki/front-proxy-client.key
--requestheader-allowed-names=front-proxy-client
--requestheader-client-ca-file=/etc/kubernetes/pki/front-proxy-ca.crt
--requestheader-extra-headers-prefix=X-Remote-Extra-
--requestheader-group-headers=X-Remote-Group
--requestheader-username-headers=X-Remote-User
--secure-port=6443
--service-account-issuer=https://kubernetes.default.svc.cluster.local
--service-account-key-file=/etc/kubernetes/pki/sa.pub
--service-account-signing-key-file=/etc/kubernetes/pki/sa.key
--service-cluster-ip-range=172.233.0.0/18
--tls-cert-file=/etc/kubernetes/pki/apiserver.crt
--tls-private-key-file=/etc/kubernetes/pki/apiserver.key
State: Waiting
Reason: CreateContainerError
Last State: Terminated
Reason: Error
Exit Code: 1
Started: Fri, 31 Dec 2021 14:22:47 +0800
Finished: Fri, 31 Dec 2021 14:23:08 +0800
Ready: False
Restart Count: 6
Requests:
cpu: 250m
Liveness: http-get https://192.168.115.43:6443/livez delay=10s timeout=15s period=10s #success=1 #failure=8
Readiness: http-get https://192.168.115.43:6443/readyz delay=0s timeout=15s period=1s #success=1 #failure=3
Startup: http-get https://192.168.115.43:6443/livez delay=10s timeout=15s period=10s #success=1 #failure=24
Environment: <none>
Mounts:
/etc/kubernetes/pki from k8s-certs (ro)
/etc/pki from etc-pki (ro)
/etc/ssl/certs from ca-certs (ro)
/etc/ssl/etcd/ssl from etcd-certs-0 (ro)
Conditions:
Type Status
Initialized True
Ready False
ContainersReady False
PodScheduled True
Volumes:
ca-certs:
Type: HostPath (bare host directory volume)
Path: /etc/ssl/certs
HostPathType: DirectoryOrCreate
etc-pki:
Path: /etc/pki
etcd-certs-0:
Path: /etc/ssl/etcd/ssl
k8s-certs:
Path: /etc/kubernetes/pki
QoS Class: Burstable
Node-Selectors: <none>
Tolerations: :NoExecute op=Exists
Events:
Type Reason Age From Message
Normal Pulled 2m51s (x67177 over 10d) kubelet Container image “registry.cn-beijing.aliyuncs.com/kubesphereio/kube-apiserver:v1.21.5” already present on machine
[root@master-01 ~]# kubectl logs kube-apiserver-master-01 -n kube-system
Flag –insecure-port has been deprecated, This flag has no effect now and will be removed in v1.24.
I1231 06:22:47.871738 1 server.go:629] external host was not specified, using 192.168.115.43
I1231 06:22:47.872615 1 server.go:181] Version: v1.21.5
I1231 06:22:48.664334 1 shared_informer.go:240] Waiting for caches to sync for node_authorizer
I1231 06:22:48.665523 1 plugins.go:158] Loaded 12 mutating admission controller(s) successfully in the following order: NamespaceLifecycle,LimitRanger,ServiceAccount,NodeRestriction,TaintNodesByCondition,Priority,DefaultTolerationSeconds,DefaultStorageClass,StorageObjectInUseProtection,RuntimeClass,DefaultIngressClass,MutatingAdmissionWebhook.
I1231 06:22:48.665541 1 plugins.go:161] Loaded 10 validating admission controller(s) successfully in the following order: LimitRanger,ServiceAccount,Priority,PersistentVolumeClaimResize,RuntimeClass,CertificateApproval,CertificateSigning,CertificateSubjectRestriction,ValidatingAdmissionWebhook,ResourceQuota.
I1231 06:22:48.666776 1 plugins.go:158] Loaded 12 mutating admission controller(s) successfully in the following order: NamespaceLifecycle,LimitRanger,ServiceAccount,NodeRestriction,TaintNodesByCondition,Priority,DefaultTolerationSeconds,DefaultStorageClass,StorageObjectInUseProtection,RuntimeClass,DefaultIngressClass,MutatingAdmissionWebhook.
I1231 06:22:48.666791 1 plugins.go:161] Loaded 10 validating admission controller(s) successfully in the following order: LimitRanger,ServiceAccount,Priority,PersistentVolumeClaimResize,RuntimeClass,CertificateApproval,CertificateSigning,CertificateSubjectRestriction,ValidatingAdmissionWebhook,ResourceQuota.
I1231 06:22:48.669792 1 client.go:360] parsed scheme: “endpoint”
I1231 06:22:48.669844 1 endpoint.go:68] ccResolverWrapper: sending new addresses to cc: [{https://192.168.115.43:2379 <nil> 0 <nil>} {https://192.168.115.44:2379 <nil> 0 <nil>} {https://192.168.115.45:2379 <nil> 0 <nil>}]
W1231 06:22:48.670060 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.45:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.45:2379: connect: network is unreachable”. Reconnecting…
W1231 06:22:48.670082 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.43:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.43:2379: connect: network is unreachable”. Reconnecting…
W1231 06:22:48.670124 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.44:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.44:2379: connect: network is unreachable”. Reconnecting…
I1231 06:22:49.664138 1 client.go:360] parsed scheme: “endpoint”
I1231 06:22:49.664175 1 endpoint.go:68] ccResolverWrapper: sending new addresses to cc: [{https://192.168.115.43:2379 <nil> 0 <nil>} {https://192.168.115.44:2379 <nil> 0 <nil>} {https://192.168.115.45:2379 <nil> 0 <nil>}]
W1231 06:22:49.664331 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.45:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.45:2379: connect: network is unreachable”. Reconnecting…
W1231 06:22:49.664337 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.43:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.43:2379: connect: network is unreachable”. Reconnecting…
W1231 06:22:49.664377 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.44:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.44:2379: connect: network is unreachable”. Reconnecting…
W1231 06:22:49.670372 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.43:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.43:2379: connect: network is unreachable”. Reconnecting…
W1231 06:22:49.670406 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.44:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.44:2379: connect: network is unreachable”. Reconnecting…
W1231 06:22:49.670492 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.45:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.45:2379: connect: network is unreachable”. Reconnecting…
W1231 06:22:50.664837 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.44:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.44:2379: connect: network is unreachable”. Reconnecting…
W1231 06:22:50.664983 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.43:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.43:2379: connect: network is unreachable”. Reconnecting…
W1231 06:22:50.665020 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.45:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.45:2379: connect: network is unreachable”. Reconnecting…
W1231 06:22:50.984998 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.44:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.44:2379: connect: network is unreachable”. Reconnecting…
W1231 06:22:51.042489 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.43:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.43:2379: connect: network is unreachable”. Reconnecting…
W1231 06:22:51.050944 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.45:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.45:2379: connect: network is unreachable”. Reconnecting…
W1231 06:22:52.052672 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.45:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.45:2379: connect: network is unreachable”. Reconnecting…
W1231 06:22:52.125347 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.44:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.44:2379: connect: network is unreachable”. Reconnecting…
W1231 06:22:52.196622 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.43:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.43:2379: connect: network is unreachable”. Reconnecting…
W1231 06:22:53.436305 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.43:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.43:2379: connect: network is unreachable”. Reconnecting…
W1231 06:22:53.734935 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.44:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.44:2379: connect: network is unreachable”. Reconnecting…
W1231 06:22:53.903052 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.45:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.45:2379: connect: network is unreachable”. Reconnecting…
W1231 06:22:54.641857 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.43:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.43:2379: connect: network is unreachable”. Reconnecting…
W1231 06:22:54.818056 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.44:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.44:2379: connect: network is unreachable”. Reconnecting…
W1231 06:22:55.059955 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.45:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.45:2379: connect: network is unreachable”. Reconnecting…
W1231 06:22:57.456980 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.44:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.44:2379: connect: network is unreachable”. Reconnecting…
W1231 06:22:58.121430 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.43:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.43:2379: connect: network is unreachable”. Reconnecting…
W1231 06:22:58.174500 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.45:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.45:2379: connect: network is unreachable”. Reconnecting…
W1231 06:22:58.405488 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.45:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.45:2379: connect: network is unreachable”. Reconnecting…
W1231 06:22:58.679453 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.44:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.44:2379: connect: network is unreachable”. Reconnecting…
W1231 06:22:59.557740 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.43:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.43:2379: connect: network is unreachable”. Reconnecting…
W1231 06:23:03.800026 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.43:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.43:2379: connect: network is unreachable”. Reconnecting…
W1231 06:23:04.055979 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.45:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.45:2379: connect: network is unreachable”. Reconnecting…
W1231 06:23:04.371651 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.44:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.44:2379: connect: network is unreachable”. Reconnecting…
W1231 06:23:04.398193 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.44:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.44:2379: connect: network is unreachable”. Reconnecting…
W1231 06:23:04.625043 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.45:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.45:2379: connect: network is unreachable”. Reconnecting…
W1231 06:23:05.667564 1 clientconn.go:1223] grpc: addrConn.createTransport failed to connect to {https://192.168.115.43:2379 <nil> 0 <nil>}. Err :connection error: desc = “transport: Error while dialing dial tcp 192.168.115.43:2379: connect: network is unreachable”. Reconnecting…
Error: context deadline exceeded
