安装kubesphere 过程中出现prometheus pod 卷失败
安装方式:
kubectl apply -f https://github.com/kubesphere/ks-installer/releases/download/v3.2.1/kubesphere-installer.yaml
kubectl apply -f https://github.com/kubesphere/ks-installer/releases/download/v3.2.1/cluster-configuration.yaml
报错信息
Warning FailedMount 5m43s kubelet Unable to attach or mount volumes: unmounted volumes=[prometheus-k8s-db], unattached volumes=[config config-out tls-assets prometheus-k8s-db prometheus-k8s-rulefiles-0 kube-api-access-p5gfc]: timed out waiting for the condition
Warning FailedMount 3m29s (x3 over 10m) kubelet Unable to attach or mount volumes: unmounted volumes=[prometheus-k8s-db], unattached volumes=[config-out tls-assets prometheus-k8s-db prometheus-k8s-rulefiles-0 kube-api-access-p5gfc config]: timed out waiting for the condition
Warning FailedMount 75s (x3 over 14m) kubelet Unable to attach or mount volumes: unmounted volumes=[prometheus-k8s-db], unattached volumes=[kube-api-access-p5gfc config config-out tls-assets prometheus-k8s-db prometheus-k8s-rulefiles-0]: timed out waiting for the condition
Warning FailedMount 29s (x16 over 16m) kubelet MountVolume.NewMounter initialization failed for volume “pvc-adb80b9f-289d-472c-b6b1-59f40c2e823d” : path “/var/openebs/local/pvc-adb80b9f-289d-472c-b6b1-59f40c2e823d” does not exist
pvc
pvc-adb80b9f-289d-472c-b6b1-59f40c2e823d 20Gi RWO Delete Bound kubesphere-monitoring-system/prometheus-k8s-db-prometheus-k8s-1 local-hostpath 23m
使用openebs localstorage 自动创建pv,在pod 对应节点上检查发现对应目录/var/openebs/local/pvc-adb80b9f-289d-472c-b6b1-59f40c2e823d 已被创建,并且权限是777
请问有谁遇到过这个问题吗?
