centos7.9
Client Version: version.Info{Major:“1”, Minor:“18”, GitVersion:“v1.18.6”, GitCommit:“dff82dc0de47299ab66c83c626e08b245ab19037”, GitTreeState:“clean”, BuildDate:“2020-07-15T16:58:53Z”, GoVersion:“go1.13.9”, Compiler:“gc”, Platform:“linux/amd64”}
Server Version: version.Info{Major:“1”, Minor:“18”, GitVersion:“v1.18.6”, GitCommit:“dff82dc0de47299ab66c83c626e08b245ab19037”, GitTreeState:“clean”, BuildDate:“2020-07-15T16:51:04Z”, GoVersion:“go1.13.9”, Compiler:“gc”, Platform:“linux/amd64”}
Client:
Version: 20.10.9
API version: 1.41
Go version: go1.16.8
Git commit: c2ea9bc
Built: Mon Oct 4 16:03:22 2021
Experimental: true
Version: 20.10.9
Git commit: 79ea9d3
Built: Mon Oct 4 16:07:30 2021
Version: v1.4.11
GitCommit: 5b46e404f6b9f661a205e28d59c982d3634148f8
Version: 1.0.2
GitCommit: v1.0.2-0-g52b36a2d
Version: 0.19.0
GitCommit: de40ad0
v3.2.1。离在线安装。使用kk安装kubesphere和k8s。
一直停留在please wait for installation to complete。
查看ks-installer的日志显示如下:
the implicit localhost does not match ‘all’
TASK [download : Generating images list] ***************************************
skipping: [localhost]
TASK [download : Synchronizing images] *****************************************
TASK [kubesphere-defaults : KubeSphere | Setting images’ namespace override] ***
TASK [kubesphere-defaults : KubeSphere | Configuring defaults] *****************
ok: [localhost] => {
"msg": "Check roles/kubesphere-defaults/defaults/main.yml"
TASK [preinstall : KubeSphere | Stopping if Kubernetes version is nonsupport] ***
fatal: [localhost]: FAILED! => {
"assertion": "kubernetes_version is version('v1.19.0', '>=')",
"changed": false,
"evaluated_to": false,
"msg": "The current Kubernetes version is not supported !"
localhost : ok=1 changed=0 unreachable=0 failed=1 skipped=3 rescued=0 ignored=0
