- 虚拟化工具:Oracle VM VirtualBox
- 系统版本:Centos7.9 minimal
- 内核版本:5.19.10-1.el7.elrepo.x86_64
- 2Core 4G内存 一主两从
{Major:“1”, Minor:“24”, GitVersion:“v1.24.2”, GitCommit:“f66044f4361b9f1f96f0053dd46cb7dce5e990a8”, GitTreeState:“clean”, BuildDate:“2022-06-15T14:22:29Z”, GoVersion:“go1.18.3”, Compiler:“gc”, Platform:“linux/amd64”}
ps. 当然我知道1.24还不支持,但是我想试一下
- 版本:20.10.18
- API版本:1.41
- Go版本:1.18.6
实际用的应该是containerd+runc
k8s上最小化安装, v3.3
无法安装完成
ks-controller-manager卡ContainerCreating
kubectl describe pod ks-controller-manager-6bc65d7478-8pgsv -n kubesphere-system
ks-apiserver卡ContainerCreating
kubectl describe pod ks-apiserver-5496b564c5-zt5jg -n kubesphere-system
关于installer
kubectl logs -n kubesphere-system $(kubectl get pod -n kubesphere-system -l 'app in (ks-install, ks-installer)' -o jsonpath='{.items[0].metadata.name}') -f
2022-09-27T10:52:23+08:00 INFO : shell-operator latest
2022-09-27T10:52:23+08:00 INFO : Use temporary dir: /tmp/shell-operator
2022-09-27T10:52:23+08:00 INFO : Initialize hooks manager …
2022-09-27T10:52:23+08:00 INFO : Search and load hooks …
2022-09-27T10:52:23+08:00 INFO : Load hook config from ‘/hooks/kubesphere/installRunner.py’
2022-09-27T10:52:23+08:00 INFO : HTTP SERVER Listening on 0.0.0.0:9115
2022-09-27T10:52:24+08:00 INFO : Load hook config from ‘/hooks/kubesphere/schedule.sh’
2022-09-27T10:52:24+08:00 INFO : Initializing schedule manager …
2022-09-27T10:52:24+08:00 INFO : KUBE Init Kubernetes client
2022-09-27T10:52:24+08:00 INFO : KUBE-INIT Kubernetes client is configured successfully
2022-09-27T10:52:24+08:00 INFO : MAIN: run main loop
2022-09-27T10:52:24+08:00 INFO : MAIN: add onStartup tasks
2022-09-27T10:52:24+08:00 INFO : QUEUE add all HookRun@OnStartup
2022-09-27T10:52:24+08:00 INFO : MSTOR Create new metric shell_operator_live_ticks
2022-09-27T10:52:24+08:00 INFO : MSTOR Create new metric shell_operator_tasks_queue_length
2022-09-27T10:52:24+08:00 INFO : Running schedule manager …
2022-09-27T10:52:24+08:00 INFO : GVR for kind ‘ClusterConfiguration’ is installer.kubesphere.io/v1alpha1, Resource=clusterconfigurations
2022-09-27T10:52:24+08:00 INFO : EVENT Kube event ‘ef9fe461-f69a-4032-90e4-ba885e631850’
2022-09-27T10:52:24+08:00 INFO : QUEUE add TASK_HOOK_RUN@KUBE_EVENTS kubesphere/installRunner.py
2022-09-27T10:52:27+08:00 INFO : TASK_RUN HookRun@KUBE_EVENTS kubesphere/installRunner.py
2022-09-27T10:52:27+08:00 INFO : Running hook ‘kubesphere/installRunner.py’ binding ‘KUBE_EVENTS’ …
Delete old cluster configuration successfully
Create cluster configuration successfully
2022-09-27T10:52:28+08:00 INFO : EVENT Kube event ‘ef9fe461-f69a-4032-90e4-ba885e631850’
2022-09-27T10:52:28+08:00 INFO : QUEUE add TASK_HOOK_RUN@KUBE_EVENTS kubesphere/installRunner.py
2022-09-27T10:52:30+08:00 INFO : TASK_RUN HookRun@KUBE_EVENTS kubesphere/installRunner.py
2022-09-27T10:52:30+08:00 INFO : Running hook ‘kubesphere/installRunner.py’ binding ‘KUBE_EVENTS’ …
the implicit localhost does not match ‘all’
TASK [download : Generating images list] ***************************************
skipping: [localhost]
TASK [download : Synchronizing images] *****************************************
TASK [kubesphere-defaults : KubeSphere | Setting images’ namespace override] ***
TASK [kubesphere-defaults : KubeSphere | Configuring defaults] *****************
ok: [localhost] => {
“msg”: “Check roles/kubesphere-defaults/defaults/main.yml”
TASK [preinstall : KubeSphere | Stopping if Kubernetes version is nonsupport] ***
“changed”: false,
“msg”: “All assertions passed”
TASK [preinstall : KubeSphere | Checking StorageClass] *************************
changed: [localhost]
TASK [preinstall : KubeSphere | Stopping if StorageClass was not found] ********
TASK [preinstall : KubeSphere | Checking default StorageClass] *****************
TASK [preinstall : KubeSphere | Stopping if default StorageClass was not found] ***
“changed”: false,
TASK [preinstall : KubeSphere | Checking KubeSphere component] *****************
TASK [preinstall : KubeSphere | Getting KubeSphere component version] **********
skipping: [localhost] => (item=ks-openldap)
skipping: [localhost] => (item=ks-redis)
skipping: [localhost] => (item=ks-minio)
skipping: [localhost] => (item=ks-openpitrix)
skipping: [localhost] => (item=elasticsearch-logging)
skipping: [localhost] => (item=elasticsearch-logging-curator)
skipping: [localhost] => (item=istio)
skipping: [localhost] => (item=istio-init)
skipping: [localhost] => (item=jaeger-operator)
skipping: [localhost] => (item=ks-jenkins)
skipping: [localhost] => (item=ks-sonarqube)
skipping: [localhost] => (item=logging-fluentbit-operator)
skipping: [localhost] => (item=uc)
skipping: [localhost] => (item=metrics-server)
localhost : ok=7 changed=4 unreachable=0 failed=0 skipped=5 rescued=0 ignored=0
TASK [Metrics-Server | Getting metrics-server installation files] **************
skipping: [localhost] => (item={‘file’: ‘metrics-server.yaml’})
TASK [metrics-server : Metrics-Server | Checking Metrics-Server] ***************
TASK [Metrics-Server | Uninstalling old metrics-server] ************************
TASK [Metrics-Server | Installing new metrics-server] **************************
TASK [metrics-server : Metrics-Server | Waitting for metrics.k8s.io ready] *****
TASK [Metrics-Server | Importing metrics-server status] ************************
localhost : ok=1 changed=0 unreachable=0 failed=0 skipped=10 rescued=0 ignored=0
TASK [common : KubeSphere | Checking kube-node-lease namespace] ****************
TASK [common : KubeSphere | Getting system namespaces] *************************
ok: [localhost]
TASK [common : set_fact] *******************************************************
ok: [localhost]
TASK [common : debug] **********************************************************
“msg”: [
“kubesphere-system”,
“kubesphere-controls-system”,
“kubesphere-monitoring-system”,
“kubesphere-monitoring-federated”,
“kube-node-lease”
TASK [common : KubeSphere | Creating KubeSphere namespace] *********************
changed: [localhost] => (item=kubesphere-system)
changed: [localhost] => (item=kubesphere-controls-system)
changed: [localhost] => (item=kubesphere-monitoring-system)
changed: [localhost] => (item=kubesphere-monitoring-federated)
changed: [localhost] => (item=kube-node-lease)
TASK [common : KubeSphere | Labeling system-workspace] *************************
changed: [localhost] => (item=default)
changed: [localhost] => (item=kube-public)
changed: [localhost] => (item=kube-system)
TASK [common : KubeSphere | Labeling namespace for network policy] *************
TASK [common : KubeSphere | Getting Kubernetes master num] *********************
TASK [common : KubeSphere | Setting master num] ********************************
ok: [localhost]
TASK [KubeSphere | Getting common component installation files] ****************
changed: [localhost] => (item=common)
TASK [common : KubeSphere | Checking Kubernetes version] ***********************
changed: [localhost] => (item=snapshot-controller)
TASK [common : KubeSphere | Creating snapshot controller values] ***************
changed: [localhost] => (item={‘name’: ‘custom-values-snapshot-controller’, ‘file’: ‘custom-values-snapshot-controller.yaml’})
TASK [common : KubeSphere | Updating snapshot crd] *****************************
TASK [common : KubeSphere | Deploying snapshot controller] *********************
TASK [KubeSphere | Checking openpitrix common component] ***********************
fatal: [localhost]: FAILED! => {“changed”: true, “cmd”: “/usr/local/bin/kubectl get pod -n openpitrix-system\n”, “delta”: “0:00:02.699491”, “end”: “2022-09-27 10:54:39.722422”, “msg”: “non-zero return code”, “rc”: 1, “start”: “2022-09-27 10:54:37.022931”, “stderr”: “Unable to connect to the server: dial tcp 10.96.0.1:443: connect: no route to host”, “stderr_lines”: [“Unable to connect to the server: dial tcp 10.96.0.1:443: connect: no route to host”], “stdout”: "", “stdout_lines”: []}
localhost : ok=16 changed=11 unreachable=0 failed=1 skipped=3 rescued=0 ignored=0
关于所有pod
NAMESPACE NAME READY STATUS RES TARTS AGE
calico-apiserver calico-apiserver-87f8c8cdc-745mm 1/1 Running 7 ( 6m29s ago) 57m
calico-apiserver calico-apiserver-87f8c8cdc-x5pbh 1/1 Running 4 ( 64m ago) 20h
calico-system calico-kube-controllers-5b8957ccd7-vfwk4 1/1 Running 4 ( 6m9s ago) 57m
calico-system calico-node-jr7ll 1/1 Running 2 ( 35m ago) 25h
calico-system calico-node-lzxlh 1/1 Running 1 ( 155m ago) 25h
calico-system calico-node-svtd9 1/1 Running 3 ( 63m ago) 25h
calico-system calico-typha-84898fcf9b-jn78k 1/1 Running 4 ( 35m ago) 25h
calico-system calico-typha-84898fcf9b-n2xgp 1/1 Running 2 ( 153m ago) 25h
calico-system csi-node-driver-8zffd 2/2 Running 2 ( 154m ago) 25h
calico-system csi-node-driver-b52sp 2/2 Running 2 ( 155m ago) 25h
calico-system csi-node-driver-wcfz5 2/2 Running 4 ( 35m ago) 25h
kube-system coredns-7f74c56694-d7×8z 1/1 Running 1 ( 154m ago) 20h
kube-system coredns-7f74c56694-vxm84 1/1 Running 0 57m
kube-system etcd-k8s-master-0 1/1 Running 6 ( 87m ago) 4d19h
kube-system kube-apiserver-k8s-master-0 1/1 Running 6 ( 154m ago) 4d19h
kube-system kube-controller-manager-k8s-master-0 1/1 Running 31 (33m ago) 4d19h
kube-system kube-proxy-p6l2f 1/1 Running 1 ( 155m ago) 21h
kube-system kube-proxy-ttszg 1/1 Running 1 ( 154m ago) 21h
kube-system kube-proxy-wdffj 1/1 Running 2 ( 35m ago) 21h
kube-system kube-scheduler-k8s-master-0 1/1 Running 29 (53m ago) 4d19h
kube-system metrics-server-6df598dddf-mf6xs 1/1 Running 1 ( 6m38s ago) 57m
kube-system snapshot-controller-0 1/1 Running 0 132m
kubernetes-dashboard dashboard-metrics-scraper-8c47d4b5d-slszw 1/1 Running 0 57m
kubernetes-dashboard kubernetes-dashboard-67bd8fc546-kdlvr 1/1 Running 1 ( 5m45s ago) 57m
kubesphere-controls-system default-http-backend-69478ff5f9-99pkw 1/1 Running 0 57m
kubesphere-system ks-apiserver-5496b564c5-zt5jg 0/1 ContainerCreating 0 61m
kubesphere-system ks-console-99dc7cb7c-rnz8q 1/1 Running 0 61m
kubesphere-system ks-controller-manager-6bc65d7478-8pgsv 0/1 ContainerCreating 0 61m
kubesphere-system ks-installer-b6954b57f-nxl76 1/1 Running 3 ( 56m ago) 57m
tigera-operator tigera-operator-6bb888d6fc-hbbmt 1/1 Running 20 (7m32s ago) 26h
关于网络
10.96.0.0/16是服务网段
default kubernetes ClusterIP 10.96.0.1 <none> 443/TCP 4d19h
