hongming 脚本是一致的,我对比了一下,下载文档说明的脚本
xingxing122 upgrade.sh 可以重复执行的,脚本没有修改过吧?别把 set -e 去掉了,正常运行肯定会执行到上面我列出的这行命令
    hongming 我之前用patch 打上helm 标签,我取消试试,for r in globalroles.iam.kubesphere.io globalrolebindings.iam.kubesphere.io workspacetemplates.tenant.kubesphere.io clusterroles.iam.kubesphere.io clusterrolebindings.iam.kubesphere.io; do \
    kubectl get $r -o name | xargs -I{} kubectl label {} app.kubernetes.io/managed-by=Helm –overwrite; \
    kubectl get $r -o name | xargs -I{} kubectl annotate {} meta.helm.sh/release-name=ks-core meta.helm.sh/release-namespace=kubesphere-system –overwrite; \
    done
    脚本没有修改过,我取消打的标签,重新跑一下脚本
    有执行命令,但是看是报错了
    apply CRDs
    Error: invalid argument "server" for "--dry-run" flag: strconv.ParseBool: parsing "server": invalid syntax
    error: no objects passed to apply
    customresourcedefinition.apiextensions.k8s.io/applications.app.k8s.io configured
    customresourcedefinition.apiextensions.k8s.io/applicationreleases.application.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/applications.application.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/applicationversions.application.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/categories.application.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/repos.application.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/clusters.cluster.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/labels.cluster.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/apiservices.extensions.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/extensionentries.extensions.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/jsbundles.extensions.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/reverseproxies.extensions.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/ingressclassscopes.gateway.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/builtinroles.iam.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/categories.iam.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/clusterrolebindings.iam.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/clusterroles.iam.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/globalrolebindings.iam.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/globalroles.iam.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/groupbindings.iam.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/groups.iam.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/loginrecords.iam.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/rolebindings.iam.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/roles.iam.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/roletemplates.iam.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/users.iam.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/workspacerolebindings.iam.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/workspaceroles.iam.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/categories.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/extensions.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/extensionversions.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/installplans.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/repositories.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/serviceaccounts.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/resourcequotas.quota.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/provisionercapabilities.storage.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/storageclasscapabilities.storage.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/workspaces.tenant.kubesphere.io unchanged
    customresourcedefinition.apiextensions.k8s.io/workspacetemplates.tenant.kubesphere.io unchanged
    review your upgrade values.yaml and make sure the extension configs matches the extension you published, you have 10 seconds before upgrade starts.
    upgrade.go:142: [debug] preparing upgrade for ks-core
    upgrade.go:150: [debug] performing update for ks-core
    Error: UPGRADE FAILED: rendered manifests contain a resource that already exists. Unable to continue with update: GlobalRole "anonymous" in namespace "" exists and cannot be imported into the current release: invalid ownership metadata; label validation error: missing key "app.kubernetes.io/managed-by": must be set to "Helm"; annotation validation error: missing key "meta.helm.sh/release-name": must be set to "ks-core"; annotation validation error: missing key "meta.helm.sh/release-namespace": must be set to "kubesphere-system"
    helm.go:84: [debug] GlobalRole "anonymous" in namespace "" exists and cannot be imported into the current release: invalid ownership metadata; label validation error: missing key "app.kubernetes.io/managed-by": must be set to "Helm"; annotation validation error: missing key "meta.helm.sh/release-name": must be set to "ks-core"; annotation validation error: missing key "meta.helm.sh/release-namespace": must be set to "kubesphere-system"
    helm.sh/helm/v3/pkg/action.(\*Upgrade).performUpgrade
    	helm.sh/helm/v3/pkg/action/upgrade.go:301
    helm.sh/helm/v3/pkg/action.(\*Upgrade).RunWithContext
    	helm.sh/helm/v3/pkg/action/upgrade.go:151
    main.newUpgradeCmd.func2
    	helm.sh/helm/v3/cmd/helm/upgrade.go:199
    github.com/spf13/cobra.(\*Command).execute
    	github.com/spf13/cobra@v1.5.0/command.go:872
    github.com/spf13/cobra.(\*Command).ExecuteC
    	github.com/spf13/cobra@v1.5.0/command.go:990
    	github.com/spf13/cobra@v1.5.0/command.go:918
    main.main
    	helm.sh/helm/v3/cmd/helm/helm.go:83
    runtime.main
    	runtime/proc.go:250
    runtime.goexit
    	runtime/asm_arm64.s:1172
    UPGRADE FAILED
    	helm.sh/helm/v3/cmd/helm/upgrade.go:201
    main.main
    runtime.main
    	runtime/proc.go:250
    runtime.goexit
    脚本是不是需要完善一下,跟helm 版本也有问题吧。
      xingxing122
      是的,helm 版本需要 3.13+,我们调整一下脚本
      更新好了,可以说一下,谢谢,社区还是给力
        I0421 13:14:14.563237       1 filepath.go:71] [Storage] LocalFileStorage File directory /tmp/ks-upgrade already exists
        I0421 13:14:14.563378       1 executor.go:158] [Job] kubeedge is disabled
        I0421 13:14:14.563390       1 executor.go:158] [Job] kubefed is disabled
        I0421 13:14:14.563394       1 executor.go:158] [Job] servicemesh is disabled
        I0421 13:14:14.563396       1 executor.go:158] [Job] storage-utils is disabled
        I0421 13:14:14.563397       1 executor.go:158] [Job] tower is disabled
        I0421 13:14:14.563399       1 executor.go:158] [Job] whizard-telemetry is disabled
        I0421 13:14:14.563401       1 executor.go:158] [Job] whizard-alerting is disabled
        I0421 13:14:14.563409       1 executor.go:155] [Job] application is enabled, priority 100
        I0421 13:14:14.563413       1 executor.go:155] [Job] devops is enabled, priority 800
        I0421 13:14:14.563421       1 executor.go:155] [Job] iam is enabled, priority 999
        I0421 13:14:14.563428       1 executor.go:158] [Job] whizard-logging is disabled
        I0421 13:14:14.563431       1 executor.go:158] [Job] metrics-server is disabled
        I0421 13:14:14.563435       1 executor.go:155] [Job] network is enabled, priority 100
        I0421 13:14:14.563443       1 executor.go:155] [Job] core is enabled, priority 10000
        I0421 13:14:14.563446       1 executor.go:158] [Job] whizard-events is disabled
        I0421 13:14:14.563457       1 executor.go:155] [Job] gateway is enabled, priority 90
        I0421 13:14:14.563460       1 executor.go:158] [Job] opensearch is disabled
        I0421 13:14:14.563462       1 executor.go:158] [Job] vector is disabled
        I0421 13:14:14.563464       1 executor.go:158] [Job] whizard-monitoring is disabled
        I0421 13:14:14.563466       1 executor.go:158] [Job] whizard-notification is disabled
        I0421 13:14:14.568650       1 helm.go:145] getting history for release [ks-core]
        I0421 13:14:14.633176       1 validator.go:57] [Validator] Current release's version is v3.3.2
        I0421 13:14:14.633200       1 executor.go:220] [Job] core prepare-upgrade start
        I0421 13:14:14.633209       1 executor.go:58] [Job] Detected that the plugin core is true
        I0421 13:14:14.658523       1 core.go:314] scale down deployment kubesphere-system/ks-apiserver unchanged
        I0421 13:14:14.668097       1 core.go:314] scale down deployment kubesphere-system/ks-console unchanged
        I0421 13:14:14.680227       1 core.go:314] scale down deployment kubesphere-system/ks-controller-manager unchanged
        I0421 13:14:14.690029       1 core.go:314] scale down deployment kubesphere-system/ks-installer unchanged
        panic: runtime error: invalid memory address or nil pointer dereference
        [signal SIGSEGV: segmentation violation code=0x1 addr=0x18 pc=0x2025ccf]
        goroutine 1 [running]:
        kubesphere.io/ks-upgrade/pkg/jobs/core.(\*upgradeJob).deleteKubeSphereWebhook(0xc0009def00, {0x2ba2f40, 0x40e7c00})
        	/workspace/pkg/jobs/core/core.go:429 +0x22f
        kubesphere.io/ks-upgrade/pkg/jobs/core.(\*upgradeJob).PrepareUpgrade(0xc0009def00, {0x2ba2f40, 0x40e7c00})
        	/workspace/pkg/jobs/core/core.go:118 +0xcc
        kubesphere.io/ks-upgrade/pkg/executor.(\*Executor).PrepareUpgrade(0xc000403560, {0x2ba2f40, 0x40e7c00})
        	/workspace/pkg/executor/executor.go:227 +0x275
        main.init.func5(0xc000158600?, {0x26e5683?, 0x4?, 0x26e5687?})
        	/workspace/cmd/ks-upgrade.go:102 +0x26
        github.com/spf13/cobra.(\*Command).execute(0x4095a80, {0xc00081ce40, 0x3, 0x3})
        	/workspace/vendor/github.com/spf13/cobra/command.go:985 +0xaaa
        github.com/spf13/cobra.(\*Command).ExecuteC(0x4094c20)
        	/workspace/vendor/github.com/spf13/cobra/command.go:1117 +0x3ff
        github.com/spf13/cobra.(\*Command).Execute(...)
        	/workspace/vendor/github.com/spf13/cobra/command.go:1041
        main.main()
        	/workspace/cmd/ks-upgrade.go:136 +0x4e
        helm 更新到了3.17之后,执行报错
          • hongmingK零SK壹S
          xingxing122
          kubectl get validatingwebhookconfiguration -o json | jq '.items[] | .webhooks[] | select(.clientConfig.service == null)'
          这么检查看看,可以先把这些 validatingwebhookconfiguration clientConfig 中 service url 修改为 ServiceReference
          已提交修复,kubesphere/ks-upgrade#27
          • hongmingK零SK壹S
          xingxing122
          改一下 ks-upgrade 的 imagePullPolicy,重新拉一下镜像
          编辑 ks-core-values.yaml,把 pullPolicy 改为 Always
          upgrade:
            enabled: true
            image:
              registry: ""
              repository: kubesphere/ks-upgrade
              tag: ""
              pullPolicy: Always
            hongming 更新完毕之后,需要重新执行啥命令来加载一下呢,或者重新更新呢
            重新执行更新,还是报错, 我的电脑是mac M1 系列,跟客户是啥系统没关系吧,看这个报错,还是空指针,哪里不对
            kubectl logs -f -n kubesphere-system prepare-upgrade-rnxs8
            I0422 05:07:44.886017       1 filepath.go:71] [Storage] LocalFileStorage File directory /tmp/ks-upgrade already exists
            I0422 05:07:44.886187       1 executor.go:158] [Job] whizard-alerting is disabled
            I0422 05:07:44.886201       1 executor.go:158] [Job] whizard-logging is disabled
            I0422 05:07:44.886205       1 executor.go:158] [Job] whizard-notification is disabled
            I0422 05:07:44.886209       1 executor.go:158] [Job] tower is disabled
            I0422 05:07:44.886212       1 executor.go:158] [Job] whizard-telemetry is disabled
            I0422 05:07:44.886216       1 executor.go:158] [Job] whizard-events is disabled
            I0422 05:07:44.886220       1 executor.go:158] [Job] kubefed is disabled
            I0422 05:07:44.886224       1 executor.go:158] [Job] servicemesh is disabled
            I0422 05:07:44.886227       1 executor.go:158] [Job] storage-utils is disabled
            I0422 05:07:44.886240       1 executor.go:155] [Job] devops is enabled, priority 800
            I0422 05:07:44.886261       1 executor.go:155] [Job] iam is enabled, priority 999
            I0422 05:07:44.886272       1 executor.go:158] [Job] metrics-server is disabled
            I0422 05:07:44.886276       1 executor.go:158] [Job] opensearch is disabled
            I0422 05:07:44.886279       1 executor.go:158] [Job] whizard-monitoring is disabled
            I0422 05:07:44.886287       1 executor.go:155] [Job] network is enabled, priority 100
            I0422 05:07:44.886295       1 executor.go:158] [Job] vector is disabled
            I0422 05:07:44.886304       1 executor.go:155] [Job] application is enabled, priority 100
            I0422 05:07:44.886311       1 executor.go:155] [Job] core is enabled, priority 10000
            I0422 05:07:44.886323       1 executor.go:155] [Job] gateway is enabled, priority 90
            I0422 05:07:44.886327       1 executor.go:158] [Job] kubeedge is disabled
            I0422 05:07:44.898462       1 helm.go:145] getting history for release [ks-core]
            I0422 05:07:44.951846       1 validator.go:57] [Validator] Current release's version is v3.3.2
            I0422 05:07:44.951869       1 executor.go:220] [Job] core prepare-upgrade start
            I0422 05:07:44.951878       1 executor.go:58] [Job] Detected that the plugin core is true
            I0422 05:07:44.977148       1 core.go:314] scale down deployment kubesphere-system/ks-apiserver unchanged
            I0422 05:07:45.000332       1 core.go:314] scale down deployment kubesphere-system/ks-console unchanged
            I0422 05:07:45.006025       1 core.go:314] scale down deployment kubesphere-system/ks-controller-manager unchanged
            I0422 05:07:45.028711       1 core.go:314] scale down deployment kubesphere-system/ks-installer unchanged
            kubesphere.io/ks-upgrade/pkg/jobs/core.(\*upgradeJob).deleteKubeSphereWebhook(0xc000a2f630, {0x2ba2f40, 0x40e7c00})
            kubesphere.io/ks-upgrade/pkg/jobs/core.(\*upgradeJob).PrepareUpgrade(0xc000a2f630, {0x2ba2f40, 0x40e7c00})
            kubesphere.io/ks-upgrade/pkg/executor.(\*Executor).PrepareUpgrade(0xc000491710, {0x2ba2f40, 0x40e7c00})
            main.init.func5(0xc00021a800?, {0x26e5683?, 0x4?, 0x26e5687?})
            github.com/spf13/cobra.(\*Command).execute(0x4095a80, {0xc000898420, 0x3, 0x3})
            main.main()
              脚本就卡在这里了,
              deployment.apps/ks-installer scaled
              etcd endpointIps is empty or localhost, will be filled with
              clusterconfiguration.installer.kubesphere.io/ks-installer patched (no change)
              remove redis
              No resources found
              No resources found
              No resources found
              No resources found
              No resources found
              No resources found
              apply CRDs
              job.batch “prepare-upgrade” deleted
              configmap/ks-upgrade-prepare-config unchanged
              job.batch/prepare-upgrade created
              查看资源运行情况
              xingxing122
              检查一下 prepare-upgrade-xxxx pod 的 imagePullPolicy,镜像更新了没
                  image: docker.io/kubesphere/ks-upgrade:v4.1.3
                  imageID: docker.io/kubesphere/ks-upgrade@sha256:bbdc80bbcab3f87b020af43d177c28425af593e103133ec6defdab9488dfb3a3
                • hongmingK零SK壹S
                xingxing122
                确认一下 image hash 是否一致,我这能复现你遇到的问题,修复后也重新验证过, 相关问题的修复记录 https://github.com/kubesphere/ks-upgrade/pull/27/files#diff-a539a85bdf77e6a269d56942c9ce3f56b0e1a0d33cf1ccd03ba6081f582a17dbR429
                这一行的空指针加了前置判断,环境中配置的差异会被忽略
                请提供一下最新的日志信息,可能不是这里产生的错误了
