• 新版本升级
  • 过渡无压力!KubeSphere v3.4.x 到 v4.x 平滑升级全攻略
I0421 13:14:14.563237       1 filepath.go:71] [Storage] LocalFileStorage File directory /tmp/ks-upgrade already exists
I0421 13:14:14.563378       1 executor.go:158] [Job] kubeedge is disabled
I0421 13:14:14.563390       1 executor.go:158] [Job] kubefed is disabled
I0421 13:14:14.563394       1 executor.go:158] [Job] servicemesh is disabled
I0421 13:14:14.563396       1 executor.go:158] [Job] storage-utils is disabled
I0421 13:14:14.563397       1 executor.go:158] [Job] tower is disabled
I0421 13:14:14.563399       1 executor.go:158] [Job] whizard-telemetry is disabled
I0421 13:14:14.563401       1 executor.go:158] [Job] whizard-alerting is disabled
I0421 13:14:14.563409       1 executor.go:155] [Job] application is enabled, priority 100
I0421 13:14:14.563413       1 executor.go:155] [Job] devops is enabled, priority 800
I0421 13:14:14.563421       1 executor.go:155] [Job] iam is enabled, priority 999
I0421 13:14:14.563428       1 executor.go:158] [Job] whizard-logging is disabled
I0421 13:14:14.563431       1 executor.go:158] [Job] metrics-server is disabled
I0421 13:14:14.563435       1 executor.go:155] [Job] network is enabled, priority 100
I0421 13:14:14.563443       1 executor.go:155] [Job] core is enabled, priority 10000
I0421 13:14:14.563446       1 executor.go:158] [Job] whizard-events is disabled
I0421 13:14:14.563457       1 executor.go:155] [Job] gateway is enabled, priority 90
I0421 13:14:14.563460       1 executor.go:158] [Job] opensearch is disabled
I0421 13:14:14.563462       1 executor.go:158] [Job] vector is disabled
I0421 13:14:14.563464       1 executor.go:158] [Job] whizard-monitoring is disabled
I0421 13:14:14.563466       1 executor.go:158] [Job] whizard-notification is disabled
I0421 13:14:14.568650       1 helm.go:145] getting history for release [ks-core]
I0421 13:14:14.633176       1 validator.go:57] [Validator] Current release's version is v3.3.2
I0421 13:14:14.633200       1 executor.go:220] [Job] core prepare-upgrade start
I0421 13:14:14.633209       1 executor.go:58] [Job] Detected that the plugin core is true
I0421 13:14:14.658523       1 core.go:314] scale down deployment kubesphere-system/ks-apiserver unchanged
I0421 13:14:14.668097       1 core.go:314] scale down deployment kubesphere-system/ks-console unchanged
I0421 13:14:14.680227       1 core.go:314] scale down deployment kubesphere-system/ks-controller-manager unchanged
I0421 13:14:14.690029       1 core.go:314] scale down deployment kubesphere-system/ks-installer unchanged
panic: runtime error: invalid memory address or nil pointer dereference
[signal SIGSEGV: segmentation violation code=0x1 addr=0x18 pc=0x2025ccf]
goroutine 1 [running]:
kubesphere.io/ks-upgrade/pkg/jobs/core.(\*upgradeJob).deleteKubeSphereWebhook(0xc0009def00, {0x2ba2f40, 0x40e7c00})
	/workspace/pkg/jobs/core/core.go:429 +0x22f
kubesphere.io/ks-upgrade/pkg/jobs/core.(\*upgradeJob).PrepareUpgrade(0xc0009def00, {0x2ba2f40, 0x40e7c00})
	/workspace/pkg/jobs/core/core.go:118 +0xcc
kubesphere.io/ks-upgrade/pkg/executor.(\*Executor).PrepareUpgrade(0xc000403560, {0x2ba2f40, 0x40e7c00})
	/workspace/pkg/executor/executor.go:227 +0x275
main.init.func5(0xc000158600?, {0x26e5683?, 0x4?, 0x26e5687?})
	/workspace/cmd/ks-upgrade.go:102 +0x26
github.com/spf13/cobra.(\*Command).execute(0x4095a80, {0xc00081ce40, 0x3, 0x3})
	/workspace/vendor/github.com/spf13/cobra/command.go:985 +0xaaa
github.com/spf13/cobra.(\*Command).ExecuteC(0x4094c20)
	/workspace/vendor/github.com/spf13/cobra/command.go:1117 +0x3ff
github.com/spf13/cobra.(\*Command).Execute(...)
	/workspace/vendor/github.com/spf13/cobra/command.go:1041
main.main()
	/workspace/cmd/ks-upgrade.go:136 +0x4e
helm 更新到了3.17之后,执行报错
    • hongmingK零SK壹S
    xingxing122
    kubectl get validatingwebhookconfiguration -o json | jq '.items[] | .webhooks[] | select(.clientConfig.service == null)'
    这么检查看看,可以先把这些 validatingwebhookconfiguration clientConfig 中 service url 修改为 ServiceReference
    已提交修复,kubesphere/ks-upgrade#27
    • hongmingK零SK壹S
    xingxing122
    改一下 ks-upgrade 的 imagePullPolicy,重新拉一下镜像
    编辑 ks-core-values.yaml,把 pullPolicy 改为 Always
    upgrade:
      enabled: true
      image:
        registry: ""
        repository: kubesphere/ks-upgrade
        tag: ""
        pullPolicy: Always
      hongming 更新完毕之后,需要重新执行啥命令来加载一下呢,或者重新更新呢
      重新执行更新,还是报错, 我的电脑是mac M1 系列,跟客户是啥系统没关系吧,看这个报错,还是空指针,哪里不对
      kubectl logs -f -n kubesphere-system prepare-upgrade-rnxs8
      I0422 05:07:44.886017       1 filepath.go:71] [Storage] LocalFileStorage File directory /tmp/ks-upgrade already exists
      I0422 05:07:44.886187       1 executor.go:158] [Job] whizard-alerting is disabled
      I0422 05:07:44.886201       1 executor.go:158] [Job] whizard-logging is disabled
      I0422 05:07:44.886205       1 executor.go:158] [Job] whizard-notification is disabled
      I0422 05:07:44.886209       1 executor.go:158] [Job] tower is disabled
      I0422 05:07:44.886212       1 executor.go:158] [Job] whizard-telemetry is disabled
      I0422 05:07:44.886216       1 executor.go:158] [Job] whizard-events is disabled
      I0422 05:07:44.886220       1 executor.go:158] [Job] kubefed is disabled
      I0422 05:07:44.886224       1 executor.go:158] [Job] servicemesh is disabled
      I0422 05:07:44.886227       1 executor.go:158] [Job] storage-utils is disabled
      I0422 05:07:44.886240       1 executor.go:155] [Job] devops is enabled, priority 800
      I0422 05:07:44.886261       1 executor.go:155] [Job] iam is enabled, priority 999
      I0422 05:07:44.886272       1 executor.go:158] [Job] metrics-server is disabled
      I0422 05:07:44.886276       1 executor.go:158] [Job] opensearch is disabled
      I0422 05:07:44.886279       1 executor.go:158] [Job] whizard-monitoring is disabled
      I0422 05:07:44.886287       1 executor.go:155] [Job] network is enabled, priority 100
      I0422 05:07:44.886295       1 executor.go:158] [Job] vector is disabled
      I0422 05:07:44.886304       1 executor.go:155] [Job] application is enabled, priority 100
      I0422 05:07:44.886311       1 executor.go:155] [Job] core is enabled, priority 10000
      I0422 05:07:44.886323       1 executor.go:155] [Job] gateway is enabled, priority 90
      I0422 05:07:44.886327       1 executor.go:158] [Job] kubeedge is disabled
      I0422 05:07:44.898462       1 helm.go:145] getting history for release [ks-core]
      I0422 05:07:44.951846       1 validator.go:57] [Validator] Current release's version is v3.3.2
      I0422 05:07:44.951869       1 executor.go:220] [Job] core prepare-upgrade start
      I0422 05:07:44.951878       1 executor.go:58] [Job] Detected that the plugin core is true
      I0422 05:07:44.977148       1 core.go:314] scale down deployment kubesphere-system/ks-apiserver unchanged
      I0422 05:07:45.000332       1 core.go:314] scale down deployment kubesphere-system/ks-console unchanged
      I0422 05:07:45.006025       1 core.go:314] scale down deployment kubesphere-system/ks-controller-manager unchanged
      I0422 05:07:45.028711       1 core.go:314] scale down deployment kubesphere-system/ks-installer unchanged
      kubesphere.io/ks-upgrade/pkg/jobs/core.(\*upgradeJob).deleteKubeSphereWebhook(0xc000a2f630, {0x2ba2f40, 0x40e7c00})
      kubesphere.io/ks-upgrade/pkg/jobs/core.(\*upgradeJob).PrepareUpgrade(0xc000a2f630, {0x2ba2f40, 0x40e7c00})
      kubesphere.io/ks-upgrade/pkg/executor.(\*Executor).PrepareUpgrade(0xc000491710, {0x2ba2f40, 0x40e7c00})
      main.init.func5(0xc00021a800?, {0x26e5683?, 0x4?, 0x26e5687?})
      github.com/spf13/cobra.(\*Command).execute(0x4095a80, {0xc000898420, 0x3, 0x3})
      main.main()
        脚本就卡在这里了,
        deployment.apps/ks-installer scaled
        etcd endpointIps is empty or localhost, will be filled with
        clusterconfiguration.installer.kubesphere.io/ks-installer patched (no change)
        remove redis
        No resources found
        No resources found
        No resources found
        No resources found
        No resources found
        No resources found
        apply CRDs
        job.batch “prepare-upgrade” deleted
        configmap/ks-upgrade-prepare-config unchanged
        job.batch/prepare-upgrade created
        查看资源运行情况
        xingxing122
        检查一下 prepare-upgrade-xxxx pod 的 imagePullPolicy,镜像更新了没
            image: docker.io/kubesphere/ks-upgrade:v4.1.3
            imageID: docker.io/kubesphere/ks-upgrade@sha256:bbdc80bbcab3f87b020af43d177c28425af593e103133ec6defdab9488dfb3a3
          • hongmingK零SK壹S
          xingxing122
          确认一下 image hash 是否一致,我这能复现你遇到的问题,修复后也重新验证过, 相关问题的修复记录 https://github.com/kubesphere/ks-upgrade/pull/27/files#diff-a539a85bdf77e6a269d56942c9ce3f56b0e1a0d33cf1ccd03ba6081f582a17dbR429
          这一行的空指针加了前置判断,环境中配置的差异会被忽略
          请提供一下最新的日志信息,可能不是这里产生的错误了
          xingxing122
          只能尽可能减少环境的差异,有一些特殊配置在升级过程中可能没有被覆盖到,但能根据异常日志定位到错误 https://github.com/kubesphere/ks-upgrade,比如你遇到的这个空指针问题,就可以稍微调整一下 validatingwebhook 的配置跳过
          镜像是一致的呢,我只是打的tag 传到的仓库而已,因为mac M1 系列的本地是拉取不到arm的镜像,所以需要传到我仓库去
            xingxing122
            是不是 retag 的时候搞错了,改了 imagePullPolicy也没拉到更新后的镜像,日志中的错误信息已经足够定位问题,你也可以自己去构建镜像试试。如果觉得麻烦,可以这么跳过,把导致异常的 validatingwebhook 先备份删除,升级完成后再恢复
              hongming tag 不应该的,毕竟后面的imageID 都是一致的, 把异常的validatingwebhook 备份删除,这个操作有点麻烦,咋跳过,咋跳过呢
                xingxing122
                这个 imageID 看起来也是一致的,也是对的,但这是 x86 的,kubesphere/ks-upgrade 并没有提供 arm 镜像,你看看 prepare-upgrade 的 pod 实际拉取的是哪个呢,还有就是异常日志有没有变化,排除其它问题导致中断
                  hongming 我看了日志报错,还是那个nil 要不然就需要删除 这些,但是我觉得还是跳过比较多,我尝试使用github 上制作镜像试试
                  kubectl get validatingwebhookconfigurations | grep kubesphere
                  cluster.kubesphere.io 1 19h
                  network.kubesphere.io 1 19h
                  resourcesquotas.quota.kubesphere.io 1 19h
                  rulegroups.alerting.kubesphere.io 3 19h
                  storageclass-accessor.storage.kubesphere.io 1 19h
                  users.iam.kubesphere.io 1 19h
                    xingxing122 我拉取了master 分支,打的镜像还是有问题,这个问题修复是在那个分支搞的
                      • hongmingK零SK壹S
                      xingxing122
                      是 master 分支,这一行改动一目了然,只有 ClientConfig.Service 是指针类型
                      你再检查一下 pod,看看 imagePullPolicy 改过了吗
